Electric Eel - Introduction
Below, Arthur is playing the Electric Eel.  It's an electronic music instrument I designed to be like an acoustic instrument..  The things that  slow me down when playing most electronic instruments are having to plug into speakers and find batteries, so this instrument has its speaker and generator built in.  And as a bonus, the sound varies with how hard you play and how you move the generator, because the synthesizer can detect your playing movement and the amplifier gets louder when you player louder!  So let's get started and build one like this lovely Exertion Violin below.
Step 1Electric Eels - How to Build Your Own
To explain how it's done, we'll use this prototype Exertion Violin.  From the outside, it has three main components.  These can be thought of as similar to a violin:
  1. Expressive Generator / Strings
  2. Speaker / Violin Body
  3. Keyboard / Fret Board
In the the next picture, you can see the electronic insides.  The electronic insides have three major jobs:
  1. Rectifier - Rectify and buffer power from generator
  2. Synthesizer - Synthesize musical instrument sound
  3. Amplifier - Amplify the sound to be as loud as an acoustic instrument
In the next picture, you can see the beginnings of an instrument body.
13 comments
Jul 29, 2011. 5:51 AMgmoon says:
These things are great! I love the concept--and the expressive quality, unlike any simple electronic instruments I've ever seen! Please-embed the video--you can add it to the instructable itself.
One small point--the speaker graph on step 3--I believe that's the speaker impedance graphed to the frequency, not the frequency response itself.
I.E., it's graph of the input impedance change, not the output frequency. A large hump in the impedance around 100+ hZ is pretty typical (but a freq response like that is not).
Feb 3, 2012. 10:53 AMCheyannelovesham says:
omg thats hot lol
Nov 22, 2011. 10:17 PMchello2k9 says:
"the Electric Eel. It's an electronic music instrument I designed to be like an acoustic instrument.. The things that slow me down when playing most electronic instruments are having to plug into speakers and find batteries,"
Great idea, but a useless one...just play an acoustic instrument
Jul 29, 2011. 8:10 PMgmoon says:
For some reason, I cannot reply to your comment--the button is missing...
Anyways--the thing is, the impedance graph doesn't really tell you much about frequency response. Look at the specs of any good guitar speaker that shows both freq response and impedance vs. freq (PDF--Eminence Red Fang shows both) and there's no correlation between the two graphs. I.E., one cannot be used to predict the other--despite the LARGE peak in impedance around 100 Hz, the freq response is approx linear.
The impedance graph just illustrates that impedance changes with the frequency--but in a very non-intuitive way. That's because speakers are physical transducers, and their impedance is effected by mass, magnetism, inertia, materials, etc.
But that's OK--they work. The impedance value stamped on the speaker is an average, and that's adequate. Their general design characteristics (woofer, horn, tweeter) dictate approx how they respond.
So if you can find the frequency response graph, that would be the most useful of two metrics.
Beyond that, the resonance, etc., would be much effected by the acoustic structure--but that's another thing entirely...which I suspect you're already coming to grips with...
Aug 1, 2011. 9:32 AMgmoon says:
OK, several things...
Don't get caught up on "impedance." Impedance is just a fancy name for resistance--resistance to AC signals, so it changes with frequency. It's not an acoustic metric at all.
Thiele/Small parameters are a host of variables, LOTS of stuff.
Note that the T&S impedance "resonant" point in the Red Fang is around 100 Hz, but the acoustic "sweet spot" is between 2KHz and 5Khz  In fact, the speaker is just beginning to be linear above 100 Hz (that's useful info).
People who obsess about T&S parameters usually are looking for more bass response from a given driver. That's well and good--it's much harder to transfer energy below 80 Hz or so, than above it. Have you noticed how ultrasonic transducers (above human hearing) are tiny, but sub-woofers are huge? It's MUCH tougher to move a speaker cone at low frequencies. Much more energy is required (and wasted) in transferring low freqs.
But the overall response of most speakers is wide, despite the narrow electromagnetic resonant point that's reflected in impedance measurements. Any just about all general-purpose speakers have an impedance response that's similar to one's we've looked at. Taken by itself, It's not as significant as you're thinking...
Do cabinets matter. YES.
ALL Speakers MUST have some kind of enclosure to sound good...but it doesn't have to designed by an acoustical engineer. In fact, may fancy "ported" speakers don't sound good at all, and are just a marketing gimmick.  Others sound very good indeed; check out Bose for great audio engineering. But they design EVERYTHING from the ground up, including the transducers...
Fancy porting IS useful for getting more bass from a given driver. But it's very tricky.
The most common speaker enclosures are pretty simple. And they sound great--because they are designed to be used with simple cabinets.
Will different speaker designs have different freq responses (and impedance peaks)? Sure. They are designed that way. That's why they make woofers, tweeters, horns, etc.
Still, the reason I wrote this...
...is simple--you'll need to design speaker enclosures that enhance the frequency response of the particular instrument. I suggest you start by mimicking the structures of acoustic instruments--large tube/horn for the bass register; smaller oboe-like tubes for midrange, etc. Remember that a fixed length tube can have a very narrow resonant frequency, so play around with designs until you like the results.
Jul 30, 2011. 1:32 PMRobot Lover says:
Is that Zoz from prototype this! looks like it
Jul 28, 2011. 9:26 AMrimar2000 says:
Very interesting!
Jul 28, 2011. 3:31 AMcraig3 says:
Will you be bringing out more aswell as example of what they sound like?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:shifty
