RFID Garden Door Lock
Published
Introduction: RFID Garden Door Lock
About: My name is Hein Pragt, I have a electronic and programming background, and I like to create low cost projects. I also play keyboards and guitar, I have been a professional musician for 7 years and currently ...
This instructable will document and explain how to build a relatively cheap electric garden door lock. I have a small garden with a bicycle shed that has a door to the common area behind our house. I have a lock on this door, but a lot of people have a key, my children, my neighbor and buying a new spare key takes long and is expensive. And then people lose their key, so I thought of a simple solution where I could make many keys and could authorize, but also unauthorize keys. I though of a solution using simple 125 Khz RFID keys and a cheap reader and an Arduino Nano processor. I ordered a electric lock online because it was hard to get here in a shop and rather expensive. I gave everyone who needs access to my garden (fi. to feed the animals) a small RFID key, and created a 3D printed reader next to the door and its working fine.
This instructable will show you how I build it, because it’s all standard components, you could design your own version, if for instance you add a clock chip you could even give certain RFID keys only access at specific times. You can download all the files from my website, if hope this project will inspire you to create your own version. Regards, Hein Pragt
Step 1: So What Components Do You Need?
  • An Arduino Nano board
  • EM4100 RDM-6300 RFID card reader 125 khz (or compatible)
  • Some 125 Khz RFID badges
  • Led with 330 Ohm resistor
  • 2N7002 Mosfet
  • 10 K resistor
  • 1N4004 diode
  • 5 Volt relay
  • 7808 voltage regulator
  • 12V power supply at least 2A
  • Terminal connector for power
  • Terminal connector for lock wires
  • An electric lock (Fail-Secure)
  • PCB board to mount the parts
  • Female header pins to mount the Arduino and RFID reader. .
I usually mount the Arduino Nano and other boards with a female pin header so they can be easily replaced when broken or if they are failing. The lock needs 12V power and I wanted a single power supply, so in order to save the Arduino from becoming very hot, I put a 7808 power regulator chip between the 12V power line and the Vin of the Arduino, I use a 5 Volt relay to switch the power to the electric lock because this device will draw a lot of current. I have used a cheap 12v switching power supply, but you can use any power supply that's 12 V and can deliver at least 2 or 3 Amp current. For the RFID badges I use the read-only ones, they have a fixed number inside and are cheaper than the R/W badges,
Step 2: The Whole Diagram
This is the diagram of the lock system.I build it on a PCB board using several colors of wire, the diagram is not that complex. I use a 7808 power converter to lower the 12 voltage for the Arduino to 8 volt, I don't use the capacitors on both sides as the input power is stable and the Arduino does not use too much power. But you could put two 1 uf capacitors on bothe sides of the 7808. I use the +5v output from the Arduino to power the rest of the circuit. I use a mosfet (the old common 2n7002) to drive a relay to switch the 12 v power to the lock. As the lock can draw a lot of current its save to use a relay. I took a little plastic case to hold the electronics and I 3D printed a little case on the outside to hold the antenna and the indicator led. You can download the STL file from my website.
Step 3: The Antenna and the Indicator Led.
I placed all the components on a PCB board with terminal pins to connect the led and the antenna. I use a 3D printed antenna holder with a hole for the indicator led. I used longer wires on the indicator led and the antenna so the electronics can be mounted on the inside and the antenna on the outside. The antenna holder has 4 holes for to mount it and I used a little silicone kit to make it water proof..
Step 4: Mount the Hardware on and Next to the Door.
I also designed a holder for the lock to mount it next to the door. I also used a standard door lock on the door with a latch that will move inside when the door closes. I designed a knob to mount on the lock to be able to open the lock from the inside without a RFID badge. You can download all the STL files from my website. (The third file of the knob, the axis, should be printed with 100% infill to make it string enough) I also created a 4mm spacer for the lock, so you can mount it right in front of the latch. The lock and latch should fit loosely otherwise the unlock won’t work. I used a 12 volt 3 A switching power supply for the 12 volt and I mounted it in the top of the bicycle shed in a dry space. I have used a 3 meter wire to connect the 12 volt to the lock system.
Step 5: The Software.
I wrote a very small Arduino program to read the RFID badges and display them on the serial interface so you can read the value inside the badge. Then you can add the hexadecimal number to the array at the top of the file (don't forget to increment the number of cards below the array). When a valid card is detected the pin 12 of the Arduino controlling the relay pin will be activated for 5 seconds. You can adjust this time to your own needs. I use the software serial to read the badge so the other serial port is free for other use. There are a lot of pins left on the Arduino, you could add a I2C clock module and enable certain badges only at certain times. There is programming space left so add what you want. The basic version is working code and currently mounted in my own backyard. You can download the code on my website.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
