Introduction: Electric Generator Powering LEDs
Introduction
The Electric Generator is designed to help students understand how electricity is generated by actually allowing them to generate their own electricity. This generator is created using mostly household items. Follow the instructions below for optimal power generation. Have fun!Video:
Materials List
Cardboard | Magnet Wire | ||
Metal Rod | 2x Magnet | ||
String | Red LED (1.6v) | ||
Optional Green (2.2v) and Blue (3.8v) LED |
Suggested Tools:
- Hot Glue Gun
- Scissors
- Sandpaper
- Multi-Meter
- Wire Stripper
- Ruler
- Electrical Tape
Step 1: Building the Housing
Step One
The first thing we need to do is design the housing for the generator. The most important factor in deciding the shape and size of the housing is the size of your magnets. The magnets we are using are Ceramic Block Magnets with a size of 3/8” x 7/8” x 1-7/8”. Because of the magnet size we decided to make our housing 2-1/2” x 1-1/2” x 3”. This leaves enough room for the magnets to spin around inside the housing.Step Two
Grab your cardboard box or piece of cardboard that you will be using. The thicker or stronger the cardboard the longer it will last. We found the easiest way to build the housing is to cut one length of cardboard and fold it. In our case we cut a piece of cardboard 3” x 8”. We then folded at 1-1/2”, 4”, 5-1/2” to form a rectangle. Just like the picture above. We then used hot glue to hold the ends together. Make sure you use enough hot glue that it holds together quite well. Now that your housing is built you can start to add the wire.Step 2: Wrapping the Wire
Step One
Take the spool of copper wire and find the end. Use tape to tape down the wire to the middle of the cardboard housing. Make sure to leave enough lead wire off the top to connect your LED later.Step Two
Now start wrapping the copper wire around the middle of the housing. It is fairly important to have the wire centered around the middle as your magnet will need to be placed in the middle to have enough room to rotate. This is best done with two people, one person spinning the housing and one person holding and putting tension on the spool of wire.If you don’t have another person with you, don’t worry, you can just do it yourself by holding tension with your one hand and wrapping it around the housing.
If you have a spool already cut to the right length then keep wrapping the wire around the housing until you are out. If you do not have a spool that is cut to the right length then you will need to count. The goal is to get at least 300 wrappings. If you have less than this it would be ok, you’ll just have to spin the magnets faster to create more volts. If you decide you want me volts then wrap more than 300. The number of times around the housing will determine the volts, the gauge of the wire will determine the amps.
How do you calculate how much wire you will need for your generator? First calculate the perimeter of the housing. In our case we know that this is 8 inches because that’s how long of a piece we cut.
So we would calculate 8 inches X 300 and we get 2400 inches, if we want to find out how many feet this is we then divide this by 12. 2400/12 = 200 feet of copper wire.
Once you have finished wrapping the wire tape off the end and leave some wire for the other lead as we did for the other end. Your generator should look like the following picture, except with more wrappings of copper wire.
Step Three
The wire is coated with a layer of non conductive material to keep the electricity from going someplace you don’t want it to. The wire we are using looks very shiny, but we want to get rid of the shiny material by using sandpaper to sand it out and leave only the copper exposed so that we can connect the LED to the generator.Grab a piece of sand paper or something rough and start scraping the ends of the wires. You only need to sand an inch or two. We folded a small piece of sandpaper and place the wire in-between it and pulled so sand down two sides at once. Keeping sanding until the wire is so no longer shiny. Be careful to not sand too hard as the wire is very thin and can break.
When you have finished sanding the copper wire next you will insert the metal rod.
Step 3: Metal Rod and Magnets
Step One
Take your metal rod and with the sharp end position it in the middle of the copper wire and in the middle of the cardboard. This step is very important and may require you to insert the rod again if it is not in a good spot. The reason this is important is the magnets will be attached to the rod and when it rotates it needs to rotate smoothly without hitting the sides or ends.Make sure to look at the position of the rod at different angles when pushing through the other side to make sure that it is in the center of the other wall as well.
Once you have pushed it through spin the rod around a bit until it is easier to spin and moves somewhat freely, but not too much that it wiggles.
Step Two
The next step is to attach the magnets to the rod. This part can be a little frustrating sometimes depending on the design of the housing and the insertion of the rod. Place one magnet onto the rod in the center of the housing, then place the other magnet on the other side of the rod so that the two magnets sandwich the rod. On one model we use a bit of cardboard wedge in either side of the magnets to make the magnets sit straight, but this was not necessary.Spin the rod slowly around checking to make sure that the magnets are centered and do not hit the sides or ends of the housing. When you have gotten the magnets in a good spot then go ahead and secure them to the rod. We used hot glue and dripped it down in-between the two magnets to the metal rod. The other way that might work is to use tape and wrap it around, this worked for a bit when we tried it, but wasn’t the best.
Once you have the magnets secured to the rod then your generator is complete. If you have access to a voltmeter or multi-meter then you can hook it up to it and see how many volts you are generating.
Step 4: Add LED and String
Step One:
Take your red LED and wrap the leads of the generator to the LED’s legs. It does not matter which lead is attached to what LED leg because the generator outputs Alternating Current (AC). If it were Direct Current (DC) then the positive lead would have to be attached to the longer leg of the LED and the negative lead would be attached to the shorter leg.When you are done it should like something like this:
Go ahead and spin the rod and see if you are able to light up the LED. If it doesn’t light up right away, don’t worry. Try to spin it very quickly and check for a flicker of light. If you are not sure if it works you could hook it up to a drill and spin it with that to see if your connections are good.
Step Two:
Next we will add a string to the generator to help us spin the magnets even faster. Also, if it is done right it can act like a yo-yo and keep spinning backwards and forwards to help keep the light bright. Take your string and tie a knot onto the rod. We have found that close to the cardboard works better then at the end of the rod. Tie the knot and use a bit of hot glue to keep the knot from slipping around the rod. You may also use tape instead.Wind up of the string either by hand or by spinning the rod while holding tension on the string. Pull the string out quickly and watch the LED light up. You will notice that the string will want to start winding back up the other way, if you let it you can pull again and again and again.
If you would like to see a working version of this generator, watch:
Make It Glow
