Electric Go Kart in Retro Style (for Kids)
35,030
339
40
Published
Introduction: Electric Go Kart in Retro Style (for Kids)
About: I love to make DIY projects with my son
What ?
Electric go kart for kids which looks like retro cars from 20th. Made mainly from wood (no need for metalworks talents) and with ordinary tools like saw, drill etc.
I encourage to watch the video attached to this instructable to see how electric car look and how it drives.
Why ?
Oh, there are plenty reasons why to build a car for kids. Ask kids, especially boys and they will tell You why ;-)
What will be needed ?
- wood (pine)
- bicycle wheels
- electric engine with controller (more about it later)
- 12 batteries
- two long construction screws
- some tools but mainly saw, drill
- strong glue for wood (polyurethane would be the best)
- nails and screws
Step 1: Project Plans and Design - Boring Part ;-)
Project plan
It's important thing to know what are You going to build ;-) Don't ignore this step. Search for inspirations in the internet. Do Your research using the keywords like: go kart, kids car, cycle kart etc. When You will have in Your mind what exactly You want to build then measure Your child. Not only height, legs length but also wight. It is important property cause we are building an electric car and we have to estimate the total car+driver weight to buy proper batteries and engine.
Body/chassis design
OK, so If You have all measurements try to draw the car body shape taking in consideration following things: - how long are kids legs - this will determine the length of the mask/hood - how long are the kids hands - this will determine how high should be the steering wheel to provide comfortable grip and to avoid kicking it with the knees - what is the weight of the kid - this will determine such things like engine power, but also how strong should be the car's frame. Less weight and dimensions -> less wood for frame -> less total weight->longer driving time.
Electronic and mechanics design
The last part of Your design is to decide what engine and batteries You have to buy and how the power would be transmitted to the wheels. All of that is too complicated to describe, so I will just show You how I decided about my project.
So, I chose the 350W engine with brushes and with built in gears/transmission which reduces the RPM to 600. Why such engine ? Power - 350W is just enough to get the go kart running with top speed up to 25 km/h. Moreover, bigger power consumes bigger energy. Voltage 24V - I wanted to have 2 * 12V batteries to make my car better balanced. Batteries in front, engine in the rear part of the car. Brushes - engines with brushes are a lot of cheaper than brush-less ones. Built in RPM reduction - standard engine gives more than 2500RPM this is waaaay to much. Reduction also provides more power at slower speeds
Step 2: The Frame
First of all - You don't have to build the frame from the metal. I choose the pine wood for the frame (because it is light and flexible enough to suppress the vibrations) and the oak wood for the suspension (because it is hard and durable).
During building the frame You have to remember that only gluing or just screwing the wood isn't enough. So mix this both techniques. Nails are of course pretty bad idea ;-)
Step 3: Chassis / Car Body
The body could be made from thin plywood. It is light and easy to work with. In my project I've build some parts from plywood (the hood and the rear), but the 'door' sides I've made from 2" desks. It is because those elements will have to support the weight of the child during entering to the car.
Step 4: Painting
If You have spray gun - use it, You will have very smooth surface. If You don't have such device I recommend to use paint roller instead of brush. Roller gives smoother surface.
To get the smoothest as possible surface use the undercoat paint. If You skip this step You won't be able to cover all wood pores and the surface won't be flat. I recommend also to dilute the paint. It will give thinner coats and dry faster. This will give You more control to produce fine, flat coats.
One more thing. If You find the holes, even the smallest ones, use the spatula to cover them. If You don't do that, they will be visible after painting.
Step 5: Axles, Suspension and Wheels
Front axle
Front suspension is the trickiest part of whole project. It's hard to get parts which would work with standard bicycle wheels in the shops, You probably would have to make those parts yourself.
I've created the front suspension parts from oak and bicycle headstes (because I don't have any experience with metalworks). They are working perfectly fine even when my child is driving off road. I saw however that some people are making front suspension from ordinary pipes - i didn't try that.
Rear axle
I decided to make only one wheel powered by engine. Why ? To avoid need of differential and rigid axle. Now I know that rigid axle would be better when driving offroad, but during the build i decided not to make it because of the friction during turnings. Such friction would consume more power and drain batteries faster.
So the right wheel is attached to the heavy construction screw (with the highest strength atests) and the left wheel is spinning freely on the bicycle support.
Power is transmitted through the motorcycle chain from engine to the wheel using 'freewheel'. It's important part to avoid back current generations in the engine and avoid broken engine controller.
Step 6: Engine, Power and Electronics
As I wrote in the design section, I've used 350W electric engine. Such engine needs 24V and consumes up to 28A. It is quite a lot, so I need the really thick wires to support such current. It is the formula which You can use to determine the wire thickness considering the current, voltage and the wire length. You have to remember, that wires and DC current will generate the voltage loss. Losses depends on wire length and diameter - shorter, wider wire will produce less voltage loss.
If You don't want to play with formulas, just use the power wires from ordinary car.
To power the engine I've used two 12V (18Ah) batteries which each one weights almost 4,5kg (simmilar to those from cars). Such batteries are the cheapest but not the best for electric engines. Batteries and engines are the really wide topics, so I won't write about it more - search in the internet about this if You are curious about the best solutions. My batteries gives my son several hours of fun, so they are enough.
To control the engine You need also two more parts - the hallotron (gas pedal) and the electronic controller. Those parts could be easly bought in the shops. I've used the parts from some Chinese scooter. One thing to remember - controller must be capable to handle the engine power (and current).
Step 7: Finishing and Detailing
Finishing is so individual process that I won't write much about it. Use Your imagination. I've added to my go kart - upholstery, lights, fake radiator and of course the black horse statue on the hood :)
So that's all :)
If You are interested in this project, watch my video which is step by step tutorial on how to build electric car for kids.
Any questions ? I will answer all of them ;)
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    40 Comments
    That is really cool! :)
    It looks really nice and cool and I wanted to make it in my shop class but do to no real incramints I have to make differant type of kart.
    If you can't make it right, make it adjustable! All of your planning involved measuring the child. Unfortunately, child measurements change over time which will limit how long they will be able to use it.
    Check out cyclekarts. These are the same type of build but with gasoline instead of electric motors. They have a lot of good ideas for steering, axles, brakes, etc
    My father built me and my sister something similar when we were kids. his was a replica of the 1903 curved dash oldsmobile, and was powered by an model T ford alternator, powered by a single 12 volt car battery. was a great toy, didn't go fast but went in style big time. was a regular feature in the local sata parades and vintage car meets, and was my pride and joy. sadly im yet to have kids, but when i do they will be spoiled rotten with many similar toys as im a real jack of all trades. currently working on a couple of instructibles and this has given me a target to aim for. Awesome work mate!
    Oh, what a great dad You have. Curved dash isn't so easy to make.
    That is a very nice project. And I can see he really likes his car. But then what kid wouldn't, or even an adult for that mater. Now I see upgrades for suspension coming to dampen the rough off road driving. You could even lighten it up some going fiberglass and polyester resin with the design. Lighter means longer battery life. Bravo sir Bravo!
    Thanks. Yes You are right. Next step will be definitely rigid rear axle and the suspension.
    Could you please tell me where you got the engine and how much it cost you?
    No problem.
    Engine + controller + gear = 75 USD
    hallotron (gas pedal from scooter) and ignition - 10 USD
    freewheel + chain = 13 USD
    I've bought everything in some local (Poland) distributor which is distributor of chineese.
    You can also search fur this things on eBay
    Excellent work, well executed. I like this.. A LOT
    Great design and great idea. It has my vote . Just a few thoughts I feel that it isn't up to the person doing the instructable to have to go into every tiny little detail of the project, obviously the more info the better but if your really wanting to build something like this then you should do some more research for yourself. With the ease of the internet and the fact that the end user of the project will be different for everyone, I feel that it is up to the individual builder to make it to the style and standard of what they want it to be. It's like safety warnings if your not smart enough to work out that power tools are dangerous then you shouldn't be using them. Same as this project if your not smart enough to build one for yourself and use it safely then don't do it. If your putting your kids in something you build and it falls apart then its your fault not anyone else's. You can't blame another person for something you built not being safe enough.
    My Dad who would be 98 this year had one just like it in his youth - here's a picture of him in it....
    So I recently picked up a massive electric motor that cranks out 3500 rpm at 11/16 horsepower. The problem is that it runs on 120 volts AC. I could wire up an inverter to convert DC battery power into AC, but I'm not sure if this motor could even power a go-kart in the first place.
    Hm... in my opinion even if You would lower and convert the voltage to 12,24,36V DC this engine could not be good for an alectric car. 3500 RPMs are a lot. You would have to lower this value too. It can be done using some gears (like in bicycle) or by steering the engine with lower currents, but in such case, the power also would be lower.
    Hm.. maybe a better idea is to buy a ready to use electric engine kit ? It's not so expensive.
    Thanks, I wasn't sure. I'll probably use this motor for a different project then.
    This is an impressive and nice project! It reminds me of the "go kart" projects found in old "popular mechanix"-style magazines from the past. Kudos to you for carrying on this tradition, and sharing it with us!
    I did see a few areas which could use some improvement for safety. This is important information. As I am going to be a bit long in the details, I'm going to break this up into a series of posts:
    1. Electrical wiring (sizing for current, and proper connection techniques)
    2. The steering linkage
    3. Safety padding
    I will also discuss some alternatives around using a differential vs. solid axle vs. single drive wheel.
    I am not an expert on these subjects. I draw upon my experience with hobbyist robotics, and my experience helping a friend of mine construct, repair and maintain electric wheelchairs and mobility scooters. I have seen and experienced what can happen when things go wrong: Ccreating an impromptu electric welder is not out of the realm of possibility here!
    I'm not trying to usurp your efforts here. I instead want to expand on them for others, to help them make the best of this great project as their abilities will allow. My advice is given to you and others in the hope of making this and other projects like it as safe as possible, especially where children are concerned.
