Introduction: Free Electric Hand Warmer/Stove
Picture of Free Electric Hand Warmer/Stove
Small nine volt heater. Stop at step three for the case and the battery clip.
Step 1: Tools and Supplies
Picture of Tools and Supplies
Supplies:
Ni chrome wire or thick steel wool type thing, different thicknesses and lengths heat differently. Some wire will need more voltage to glow red hot.
9 volt battery w/ metal case
Solder
Some kind of adhesive
Tools:
Soldering iron
Utility knife
Flat head screwdriver
scissors
Step 2: Dissecting the Battery
Picture of Dissecting the Battery
Use your screwdriver to pry open the top of the battery. Inside the battery are 6 AAAA cells (you need everything but these and the bottom cover).
Step 3: Creating the Heating Element
Picture of Creating the Heating Element
Cut about 1" of whichever wire you are using and solder both ends onto the contacts on the backside of the top cover of the battery (the picture explains it better). You can also stop here and solder wires onto the contacts to use it as a battery clip and use the case for whatever you like.
Step 4: Install Heater Into Case
Picture of Install Heater Into Case
Apply your adhesive to the BOTTOM of the battery case and slide in the heating element. Try not to let the wire touch the side of the case. Wait for the adhesive to dry.
Step 5: Finishing Touches
Picture of Finishing Touches
I used the utility knife to poke holes in the side of the case.
Step 6: Testing
Picture of Testing
To test your hand warmer hook up a fresh 9 volt battery to the leads on the hand warmer. If it works then the wire inside should glow orange. DO NOT LEAVE THE BATTERY ATTACHED TO THE HEATER!!!, by doing that you are shorting out the battery and the battery will begin to heat up. To use your hand warmer attach the battery in pulses until your hand warmer is at desired temperature. If your hand warmer works than it is because the wire is resisting the flow of electricity and giving off heat as a bi product. I am proud to say that this instructable was created using recycled materials! Please do not actually TOUCH the hand warmer while it is hot. This is made so that you can use it as a small stove or warm your hands OVER it. I do not recommend sticking hot metal down your gloves.
Step 7: Thanks and Liability
Thanks for viewing my instructable. I am not liable for any burns or injuries caused by this instructable. I appreciate your ratings and comments and please vote for me in the epilog challenge. And remember to check out my other instructables and keep working to save our planet.
Thanks again.
-Ty
Green gadgets (author)2016-10-20
Well while your at it will also show use how to get 9v battery acid off outer hands :)
Xixfas (author)2012-12-10
this isnt a good idea
najito (author)2012-07-26
thank you very much
hanlin_y (author)2012-02-21
It may be safer for you to use a 5W power resistor and mount it to the metal case. That way, you can control the current with I=V/R. 0.5A is okay for AA batteries.
Lectric Wizard (author)2011-11-25
Here's a safer way to do this, get a small 12v bulb such at those used on car interior (dome) lights & wire it to an old 9v battery top as you've done here. Safe & cheap,cheap, cheap ...
dog digger (author)2011-01-02
If your worried of explosions (which I doubt) you could use a resistor of the right value.
Wesley666 (author)2009-02-19
terrible idea. Shorting a battery can make it explode emphasis on EXPLODE
chuckr44 (author)Wesley6662010-02-11
I believe all batteries sold in the US are required to have vents to vent gasses outward to prevent "kasplosions". This includes AA, AAA, C, D, and 9v batteries. Older batteries do not have vents, which is probably where you got this idea.
NatNoBrains (author)chuckr442010-11-28
!EXPLODE!
Wesley666 (author)chuckr442010-02-11
I still wouldn't trust it...safety concern, but it is a good idea other then that...
Wesley666 (author)Wesley6662009-02-19
Oh ya and !EXPLODE! if you didn't get that from above.
Derin (author)Wesley6662009-03-27
¡EXPLODE!
ReCreate (author)Wesley6662009-02-22
9-volt battery 101 the 9 volt battery has a thick metal casing,worst case scenario:the battery leaks acid
LaxLuvr (author)Wesley6662009-02-19
Thats why I said Not emphasis on Not to leave the battery attached to the heater
Wesley666 (author)LaxLuvr2009-02-20
Yes but what if it !EXPLODES! in your hand/glove or anywhere else some might put this.
LaxLuvr (author)Wesley6662009-02-20
Then I hope you have insurance and/or a spare hand!
Unless your a guy and want so warmth down there then you better have another one of those.
LaxLuvr (author)Wesley6662009-02-21
ROFL!
boredinventa (author)2010-02-28
just connect 2 nine volts together with a switch in between faster and easier but be careful because it does get super hot and will burn you very badly if used incorrectly.
Shagglepuff (author)2009-10-21
 IMA SCATMAN!
BluePhenox (author)Shagglepuff2010-01-09
no you aren't
Shagglepuff (author)BluePhenox2010-01-10
 (cries for a while)
WELL YOU'RE NOT REALLY ROB!!!!!!
I might be one of the only people in this thread that understands this... i feel old... yet wise??
fire bat (author)Uforic Invasion2010-01-08
your not alone man ^^
wtf random :P
ThaNorwegianDude (author)2009-09-15
Im 15 too! LOL
mm405416 (author)2009-03-09
I realize that this would add cost and detract the ratio of recycled materials, but isn't there some sort of IC you could put in line and would complete the circuit in pulses so that you could leave the battery attached for significantly longer?
LaxLuvr (author)mm4054162009-03-09
Thats a good idea but considering I'm 13 and don't know too much about electronics I would have to learn more about electronics if I wanted to do that.
dodo91 (author)LaxLuvr2009-03-26
im 13 too!
theghillieman (author)dodo912009-08-05
I am 13 too
Markolise (author)dodo912009-03-26
Research into 555 timers I once saw a guys website that used one of these to power a mini Tesla coil. It used a 555 timer, transformer, 2 9v batteries, and a ceramic capacitor bank. Worked rather well in my opinion :D Just a thought
luvit (author)2009-04-24
i once made a hand warmer. i took two 9v batteries and plugged the sockets into each (plus to minus). i did a lot of things during church service when i was young. i don't know why i had two 9v batts at church.
conrad2468 (author)luvit2009-05-29
lol prob for the wireless mics!
luvit (author)conrad24682009-05-31
in 1986 church mics without wires were unheard of... or it was a mic in need of wires.
conrad2468 (author)luvit2009-05-31
back-n-the-day....ha ha ha ha ha!
junits15 (author)2009-02-23
how hot does this actually get? i have made several 3 or 4 watt heaters using resistors, and they aren't shorting the battery.
LaxLuvr (author)junits152009-02-23
I don't actually know how hot it gets. I like your idea! I have used a resistor to make a putrid stink machine but it was a real pain trying to find one that reached a high temperature, especially when powered by a nine volt battery. I hope this helped to answer your question and if you have any tips on how I could improve my idea I would appreciate them.
junits15 (author)LaxLuvr2009-02-24
to improve it, you could use some nichrome wire it is a much better heating element than the steel wool
conrad2468 (author)junits152009-05-29
better.......a COIL of nichrome...just make sure its insulated....
junits15 (author)conrad24682009-05-29
exactly
sharlston (author)2009-04-25
you can get real hand warmers at hiking shops for £7 or $15 and you light the little sticky of charcoal and put them inside
A good name (author)2009-04-16
Well that couldn't at all pose a firehazard.
dodo91 (author)2009-03-26
want a hand warmer. i learned this the hard way. like he said, it will short the battery. if you connect two full 9 volts together, they will star to heat up.
Hunter4000695 (author)2009-03-10
this could be used as a fire starter. but be careful.
backscan (author)2009-03-07
Not sure on how green this is but it's a cool (sorry for the pun) idea but I was wondering if this could be improved by adding something like vegetable oil or a small water bag to the case with the steel wool to act like a heat sync and keep the wire cooler while allowing heat to build up and last longer between on and off time.
miiwii3 (author)2009-02-27
P.S battery acid deosn't hurt as bad as you think Its more of a paste than liquid. And sorry about the other comment I Wasn't trying to be mean really.
htis isn't green because it's a waste of batteries. as you may know when you short a battery you shorten It's life therefore using more batteries, going through more metal and chemicals( the ones in the battery I mean). Sure you used a dead battery as the case and the wool was recycled But that doesn't save the planet! I DON'T WANT TO BE MEAN BUT THIS ISN"T GREEN
dalbyman (author)2009-02-27
Ive been doing this for years, only ive been using it as a makeshift bomb detonator. Every time i have done this unless the battery is flat the wire just goes red hot and burns for a second or so before breaking. Are UK batteries better or something :s
ibuildcoolstuff (author)2009-02-19
wouldn't doing this short circuit the other nine volt and cause it to heat up as well?
yea so, double the heat. i would a designed differenty tho
About This Instructable
30,106views
33favorites
License:
More by LaxLuvr:Free Electric Hand Warmer/StoveFree Nine Volt Battery Clips And Small EnclosuresMy Workshop
Add instructable to:
