Electric Kiln Ceramic - Vitrofusion
4,671
104
11
Published
Introduction: Electric Kiln Ceramic - Vitrofusion
That produce a high temperature kiln?
- costs -Experience, if you can repair factories easily (if factories will learn the process and is fun, it is not theoretical but practical in action)
This is a micro summary of what made in the workshops of the faculty of art and design UNAM missions with Professor Evald Gastaldo
Por que fabricar un horno para alta temperatura ?
- costos -experiencia , si lo fabricas lo puedes repara fácilmente ( si lo fabricas aprenderás el proceso y es entretenido,no es algo teórico sino practica en acción)
Se puede fabricar un horno de alta temperatura comprando pocos materiales?
Esto es un micro resumen de lo realizado en los talleres de la facultad de arte y diseño UNAM Misiones con la Guia del profesor Evald Gastaldo
La mayoría de los materiales lo hemos rescatado de la chatarra.
Step 1: Theory
A little theory does not hurt !!
While there is nothing more exciting experience in the process,
Un poco de teoría no viene mal !!
Aunque no hay nada mas emocionante qeu experimentar en el proceso
https://en.wikipedia.org/wiki/Kiln
referencias en instructables
https://www.instructables.com/id/Homemade-Electric-...
Ideas ? links trucos , escribe los en los comentarios !!!
Step 2: Materials - Materiales
-Resistance
(Special alloy wire, is a non-ductile wire, bought in houses of ceramics, is aseptable price) (I experiment whit normal not ductil wire used in farms , but can not resist high temperatures)
-Controller
(Also there are several options and models, important that supports high temperature thermocouples 1200 ° C. Good option is to buy in china, aliexpres, etc, buy together the appropriate thermocouple to your work)
-Thermocouple
https://es.wikipedia.org/wiki/Termopar You can also fabricate buying the correct wires and attaching the tip, keep in mind the importance of ceramic insulation tubes.
-Ceramic insulators
To output resistance and terminal block are as hollow ceramic tubes, another option to serious ahorar disarm a quartz heater, in this your search something similar. Remember that if you want to drill ceramics use a vidia or diamond and water ,)
-Containment box
Any metal structure serves, just be oxidized by the passage of time and exposure to temperatures (in a box oven use a labadora vintage clothing, in others only a metal frame)
-Terminal block
Use good terminal blocks to connect the wire- resistance to the controller ,. In the connection thereof trensar wire for lower resistance, various wires for obtner less resistance and thus less heat in vulnerable areas - coneccion.
- For the insulation we can use various options
ceramic insulating brick
ceramic blanket
Aerated concrete brick (most varato and we can rummage leftovers of constructions)
https: //en.wikipedia.org/wiki/Autoclaved_aerated_c ...
All have their pros and cons, the ceramic fiber demand more work for all these jobs combiene use mask for breath, danger small particles( glass particles).
Bueno , ahora en castellano , si alguien quiere lo escribo en portuges , es casi lo mismo ;)
Resistencia
(alambre especial aleado , es un alambre no ductil , se compra en las casas de ceramica , es aseptable su precio)
( e experimentado con alambre para ganado , pero no resiste altas temperaturas )
Controlador
( tambien hay varias opciones y modelos , importante que admita termocuplas para temperaturas elevadas 1200 ºC. Una buena opcion es comprarlo en china , aliexpres ,etc , comprar junto la termocupla adecuada a tu trabajo)
Termocupla
Tambien puedes fabricarla comprando los correctos alambres y uniendo en la punta , ten en cuenta la importancia de los tubos ceramicos de aislacion .
Aisladores ceramicos
Para la salida de la resistencia y la bornera , son como tubos ceramicos huecos , otra opcion para ahorar seria desarmar una estufa a cuarzo , hay podras encontrarar algo similar . Recuerda que si queres perforar la ceramica debes usar una mecha de vidia o diamante y agua como refrigerante)
Caja de contención
Cualquier estructura de metal sirve , igual se va a oxidar por el paso de el tiempo y la exposicion a las temperaturas(en un horno usamos la caja de una labadora de ropa antigua , en otras solo una regilla metalica)
Borneras
Usar buenas borneras para conectar el alambre- resistencia a el controlador,.
En la coneccion de las mismas trensar el alambre para obtener una menor resistencia, varios alambres para obtner una menor resistencia y por lo tanto menos calor en las zonas vulnerables - coneccion.
- Para el aislante podemos usar varias opciones
Ladrillo cerámico aislante
Manta cerámica
Ladrillo Hormigón celular ( el mas varato y lo podemos rebuscar de las sobras de las construcciones )
https://en.wikipedia.org/wiki/Autoclaved_aerated_c...
Todos tienen sus pro y contras , la fibra ceramica demanda mas trabajo , para todos estos trabajos combiene utilizar mascarrilla para la respiracion , para no sufrir problemas pulmonares.
Step 3: Resistencia
Para la fabricación de la misma se compro 3kg de alambre para alta temperatura , es un alambre con una aleación especifica , recomiendo comprar por rollo a un proveedor de cerámica cercano a usted.
Datos a tener en cuenta !! cuanto mayor sea el grosor de el alambre mas temperatura sera capas de aguantar por mayor tiempo ( a su ves levantara mas lento la temperatura , y tendrá un mayor consumo de energía )
El proceso para fabricar las resistencias debe realizarse entre 2 personas , una gira la manivela metalica y la otra acomoda las espiras con una pinza.
El largo de la resistencia varia segun el horno , a experimentar !!!!
Step 4: Controladores De Temperatura - Para Programas De Rampas Y Mesetas
Temperature Controllers - Programs ramp and soak
This element is important, can not perform the work in glass, which require a temperature curve for manufacturing, they are usually purchased with different curve already scheduled, but it is easy to program for materials.
Este elemento es importante , sin el no podremos realiza trabajos en vidrio , los cuales requieren un curva de temperatura para su fabricación , se los suele comprar con las distintas curvar ya programadas , pero es facil de programarlos para los materiles.
Step 5: Probando La Maquina - Test the Machine
Remember that all parties touch the ceramic or glass that are not dirt-protecting with kaolin, will glued. :(
Recuerda que todas las partes que toque la ceramica o el vidrio que no esten protejidas con caolin , seran fucionadas !!!! ;(
Step 6:
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    11 Comments
    Other interesant proyect , more profecional
    https://www.instructables.com/id/Home-made-electric-glass-fusing-kiln/
    hello reply me at harimaabdu3@hotmail.com i have something important to tell you, i will tell you more about me when you contact me
    eeee ? you are a robot ? haahaha
    looks very interesting. Any possibility of translating sections 2 to 5 in English? The translation elsewhere was fine to follow what is going on. Thanks
    Sorry for don t answer faster . ok :)
    Why is part of it English and most of it bother
    este instructable no esta terminado , me faltaron fotos de el proceso ! ;(
