I recently picked up knife making as a hobby and got obsessed with it It took me a few months to get all the needed tools and materials like a belt sander, cutting tools, drill and... a furnace for heat threatment.
First I started with small butane forges built in a coffe can like those shown here: http://www.instructables.com/id/How-to-Make-a-small-Gas-Furnace/
Eventually I found out that this setup is not strong enought to perform the heat-treatment (HT) on pieces of metal bigger than a couple of inches (5cm) due to the high dispersions and little efficiency of the design.
This was a show-stopper to me, since if I could not HT a blade it would never become a proper knife.
I could not use complex/risky solutions that involved any gas, since I tend to mess-up and gas is very dangerous to handle. I tought about inducion heating but this was kind of scifi to my possibilities and capabilities.
So, afther much research and test, I made my electric kiln. I had to do a lot of research to fill the gaps of the many things i didn't know. I found much help in ceramic/raku kiln makers since the base is quite the same.
I did not take pictures during the assembly of the project. Both because they did not seem to be that necessary, second I doubded myself that something good would ever come out if this and that it would ever work... Sorry...
WARNING:
I was cheap both in spending money and in quality, so the result, though it works, lacks a lot of design, security and might result in being dangerous. Use all the precautions and proceed at your own risk. High voltage is used here, without much of the needed protection. Please adapt this instructions to your need and add all the safety measures that you thing might fit into it.
Also this procedure requires the use of power tools, some of those (angle grinder) are VERY dangerous and can hurt you with non reversible damage. Please take EXTREME care when using those and wear all your protective gear: safety goggles, respirator, gloves, ear protection.
Remove these ads by
Signing UpStep 1: Tools, materials and cost
angle grinder
drill
1cm diameter wood dowel
pliers, screwdrivers etc.
Google Sketch-Up
metal file
pliers
papercups and stick
Materials:
16 firebricks (for this design, your might need a different number)
1 small pack (1kg) of refractory mortar
4m stell "L" bars from metal shelves
nuts and bolts
stone-wool insulation
some old computer cases (or any other sort of metal sheet)
Kanthal A1 Wire : 12 meters in my case.
metal wire.
3 (at least) ceramic whire couplers
electric wire and plug (rated 20Amps)
Cost:
20 euros for the bricks and stone-wool
25 euros for the steel bars, nuts, bolts, anglegrinder disks
20 euros for the Kanthal A1 wire and electic stuff
0 for the metal plates
10 euros for the fire refractory mortar
Visit Our Store »
Go Pro Today »
Still the material needs to resist 1000° (C) and be NON conductive (to avoid the risk of shortcircuits should the blade fall on the side and touch the coils)
What materials are they made of? ceramic?
I've also seen ceramic rods ued to wind the wire aroud to keep them straight once the temperature makes them soft.
Forget this 'ibel anyway. Afther using it for a few months I can say that it work... but it's way too inefficient to consider it using "for real"
I'm working on the next one that will be much better. Hopefuly will be ready for the spring.
It's quite cheap to buy from glass supliers.
I made the elements using the A1 wire and it cost me about 20 dollars in TOTAL.
Plus this way I was free to have them the exact size/shape/scale/diameter/lenght I needed them.
Afther building it the main advatage I see in having pre made elements is that you don't have to cut the grooves in the bricks to set the spring into, saving a lot of work, noise, dust and maybe even your lungs...
Still this way you have to design the kiln around the elements
http://www.furnace-eng.co.nz/Kiln%20Sizes.htm
I don't know if this is at all useful, but hey.
I'll have a look at it and see if there is any good advice I mighjt use
That actually goes for version 2.0 ... someday
