3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electric Lockpick
Electric Lockpick
This is an instructable showing you how to convert Black & Decker brand electric scisors into a highly effective electric lockpick.
--- WARNING!!! ---
Building this may be illegal in your location, do not built it if it is illegal or if you are not sure.
DO NOT ASK me how to use one of those, if you do not know how it works or what it's for, do not build it. No videos or usage instructions will be provided, all PM's asking how to use it will be cheerfully ignored.
Vibrating electric picks are known for CHEWING UP the pins inside a lock with repeated use. ONLY use such a pick on your practice locks.
I am not the designer of this electric lockpick, many amateur lockpicking hobyists convert all sorts of small electric appliances into vibrating picks so I really cannot credit who came up first with the idea for this conversion.
Step 1Lets start
Lets start
First things, go buy Black and Decker brand electric scisors. They are pretty cheap, I got mine on sale at Wallyworld for aroud $10.
Take off the scisor head by pressing on the sides and pulling away.
The head is interchangeable and B&D sells replacement so you'll be able to keep this unit functionnal as scisors if you get a spare head.
28 comments
May 20, 2012. 3:23 AMkoenjah says:
I made this, worked fairly well!
It was fun enough just to make it.
Didnt even matter if it worked very well or not :P
Took me one afternoon to build.
Too bad the scissors cost me about 34 bucks.
Now I have a proffesional:
this one: http://www.lockpickwinkel.nl/pickguns/
Cya and thanks for this great and clear instructable :D
May 20, 2012. 3:28 AMkoenjah says:
Feb 12, 2012. 1:47 PMkoenjah says:
Awesome, Ive made this some time, it worked a bitt:P
too bad the sciccors was like $30 bucks..
But was still fun to make :)
I anyone wants a good one try: http://www.LockpickWinkel.nl
Cya!
May 13, 2009. 10:19 AMdanieltrevi says:
I started doing it your way, but lacking a dremel I found it taking forever. The lower scissor part was very difficult to cut with a hacksaw, and I didn't have a diamond tip drill bit to go through the pick. So I just took some EPOXY PUTTY, and a needle from a snap gun - http://www.lockpicks.com/replacementneedles.aspx - and attached the needle to the upper part of the scissors, being careful to put it on the outside of the blade so as not to interfere with the motion. It works GREAT! And much simpler.
Mar 30, 2011. 4:48 PMfligen says:
i tried the same thing, ended up buying a tool made for the job. also got a set of manual picks. i could never get the homemade mod to work right. this is the tool i purchased http://www.bumpmylock.com/e500xt-electric-lock-pick.html and it works like a champ.
Nov 21, 2011. 1:33 PMbwhite16 says:
how much does that babe cost
Nov 24, 2011. 7:39 AMUSMC sniper says:
that bad boy cost about $170 depending on where you get it....sometimes you get lucky and find a used one for less...
Apr 25, 2009. 9:24 PMhg341 says:
cool but where do you get bump keys?
Mar 30, 2011. 4:50 PMfligen says:
best place for bump keys is Bump My Lock
Dec 19, 2009. 10:53 PMmike patterson says:
hmmm, finally a use for all the old dental tools I picked up and never ground into micro-chisels....
Aug 8, 2009. 6:52 PMsharlston says:
nice ible it wilnice ible looks really cool
Apr 24, 2009. 2:17 PMcrapflinger says:
vibrating picks work by basically knocking the tumblers around in the cylinder ....you jam the pick part into the lock and put slight turning force on the entire pick while you make it vibrate (not constant...but sort of like...pull the trigger and turn...pull the trigger and turn) the turning gives the tumblers enough friction to stick in the open position after they've been vibrated out of the lock position
Apr 24, 2009. 2:18 PMcrapflinger says:
also...slight change there...usually you'd actually use some form of turning device (bent pice of metal works fine) as your turning mechanism...not sure if the OP intends to use this pick to turn as well as vibrate...i'd think probably not...so you'd have a seperate tool to do the turning part
Apr 25, 2009. 1:36 AMlemonie says:
Ah cheers "stick in the open position" is probably the key phrase. L
May 31, 2009. 5:46 PMtoogers says:
gross.
Apr 24, 2009. 2:02 PMlemonie says:
Do you know how to use this effectively? I can't see this unpicking any lock, but you don't say how it is supposed to work...
L
Apr 25, 2009. 1:33 PMSWV1787 says:
Have you ever seen those hanging balls that people have sitting on their desks that bounce the outermost balls back and forth while the middle ones stay in place? It is the same principal that a quick tap will bounce the tumblers out of the barrel and allow the barrel to rotate in the lock.
Apr 25, 2009. 5:45 PMPadlock says:
Btw that's called a "newton's cradle"
oh wait. nvm the guy below me posted before me...
Apr 25, 2009. 2:05 PMlemonie says:
Newton's cradle. But they'll also bounce back, and rotation is limited when they're not all in place. I don't doubt that it works, it's not so clear how (without the discussion) L
Apr 25, 2009. 5:46 PMPadlock says:
I always thought the way to pick a lock was to insert your blank key, and tap it with a hammer while twisting.
Apr 25, 2009. 11:26 AMBartboy says:
It vibrates the pins into place?
Apr 25, 2009. 5:41 AMlemonie says:
Thanks. I guessed you're in the Fire Service (before clicking on your profile) it's a nice thought that some people won't use the axe as a first resort.
L
Apr 24, 2009. 4:12 PMkarossii says:
if you google electric lockpick, you can find all kinds of methods to use this type of device.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:ve2vfd
Nothing much... I'm boring :)
