Remove these ads by
Signing UpStep 1Parts and Tools
Board: MBS Core 95 from MBS Mountainboards. $300
Brakes: MBS V5 Brake Kit also from MBS Mountainboards. $60
Motor: 24V 300W Electric scooter motor from my local scooter shop. $30
Sprocket and Chain: Scooter sprocket and #25 chain also from my local scooter shop. $20
Steel pieces: 16ga sheet steel, perforated square tube (14ga), perforated bar and two flat bars (14ga) from Lowes. $20
The batteries, charger, controller and throttle were all ordered from Monster Scooter Parts.
Batteries: Two 12V 10 Ah scooter batteries. $65
Charger: 24V 1.6 Amp XLR Battery Charger and XLR charging socket. $38
Controller: 24V 500W Universal Voltage and Speed Controller. $33
Throttle: Generic 4-wire thumb throttle. $13
Other parts: Wire, electrical tape, wire connectors, nuts and bolts, zip ties, tie down straps. $35
Tools Used:
Socket set
Sawhorses
Hacksaw
Hammer
Adjustable wrenches
Hex key wrenches
Pliers
Clamps
Drill and bits
Jigsaw and blades
Metal files
Wire stripper
Chainbreaker - $30 from Monster Scooter Parts
parts used:
motor:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=15201
speed controller
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7340
battery:
http://www.hobbyking.com/hobbyking/store/__15009__Turnigy_3000mAh_3S_20C_Lipo_Pack_USA_Warehouse_.html
propeller:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8057
radio (not the one i used, but much cheaper, and better for this application):
http://www.hobbyking.com/hobbyking/store/__10608__Hobby_King_GT_2_2_4Ghz_2Ch_Tx_Rx_.html
These guys took a electric longboard using CIM motor.
http://www.instructables.com/id/Electric-Longboard-Build-Clever-CIM-Motor-Drivet/
here is the battery they used http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=6518
the battery wiring is on step four
if you wanted to use the motors they used look at step 5 and 6
I have a lot of questions tho before i start spending money on the wrong stuff.
Is your setup 1 wheel drive? Do you need 2 motors(one on each wheel) and 4 batteries to make 2wd version? Wouldnt the board always turn with 1wd?
Would a Atom 90 be suitable for this?
If I am 140 pounds could i get away with a 400 watt motor? And still have good torque and speed? This would just be used for going around the neighborhood and on trails, not legit mountain boarding.
any way I can use a lever handle for throttle?
Thanks alot and great 'ible!
The MBS Atom 90 board should work fine.
Depending on how fast you want to go I would try to get the biggest motor you can afford, a 400 watt will get you around but wont be super fast.
The throttle on this is electric so if you mean a lever throttle that uses a tension wire to control speed it wont work with this setup.
Good luck on your build.
I still have some research to do so if anybody that sees this has tips, tricks, or info that could help me build an electric mountainboard, I would greatly appreciate it!
do u know if a 24 volt baterie would work instead of 2 12 volts and would it affect the speed and the other parts?
http://m.youtube.com/index?desktop_uri=%2F&gl=FR#/watch?xl=xl_blazer&v=X7g6eaY21t8
Can't even begin to grasp how awesome this is....
http://www.youtube.com/watch?v=X7g6eaY21t8&feature=related
enjoy, the guy who has made the board posted other videos ;)
inside it has blue, orange,yellow and red
orange and yellow are contected fine and it lights up but red blue and white are cut. would you be able to remember how its supposed to be . ? i havethe same throttle as you.
shaun
