Step 3Installing the support bar
A longer bolt the same size as the foot strap bolt is used to connect the support bar to the board. Rubber washers and padding are used to prevent scratching.
The upper bar and lower bracket were installed so that they did not scratch the board or interfere with the future position of the motor. The upper bar is solid steel to prevent bending at the notch and the lower bracket is perforated steel allowing it to more easily be bent around the truck.
comments
Add Comment
Add Comment
