Step 5Wiring, throttle and batteries
The controller comes with a paper describing the connectors and wire colors. Most controllers are similar and this diagram shows a good example of connector wiring: Controller wiring diagram
The only difficulty was with the throttle which had 4 wires but only 3 on the controller. After some testing the 4th wire was used as a power on indicator and I connected it to the red wire of the power light connector.
Using pin connectors and female blade connectors I replaced the originals and added an on/off switch in place of the key connector. (I also transferred the labels to the new connectors)
The motor wiring had to be reversed to make the motor run counter clockwise so the board would not run backwards.
Throttle:
The thumb throttle was placed on the end of the brake handle after removing a rubber cap. The throttle wires were then fed down through the handle and sleeve following the brake cable.
Batteries:
Two 12V scooter batteries are wired in series to provide 24V to the controller and mounted to the middle of the board using small tie down straps. This PDF file is very helpful and shows how to wire the batteries: Battery Wiring Diagrams
do u know if a 24 volt baterie would work instead of 2 12 volts and would it affect the speed and the other parts?
inside it has blue, orange,yellow and red
orange and yellow are contected fine and it lights up but red blue and white are cut. would you be able to remember how its supposed to be . ? i havethe same throttle as you.
shaun
Got most of the scooter parts from here.
http://www.scooterparts.co.nz/throttles.html
