Electric Stick Bass
Electric Stick Bass
  • last photo ←
UPDATE:012808 -Added audio file profiling the stick bass minus overdubbed guitars for clarity of tone.-
UPDATE:013108 - Added Piezo transducer close-up of back side.
An electric bass is created using 1 broken bass string, 1 piezo transducer, part of a cheap wooden easel leg, and 2 metal rods from a bookshelf. A video is included to demonstrate the sound of the stick bass.
Step 1The materials needed
Most DIYer's, I'm assuming, are pack rats like me. So having recently busted a string off my bass, I just couldn't let it go to waste. Also seeing as how I had some piezo's left over from wiring up a recent circuit bending project, the idea came to me to finally try it out.
In the corner of my workshop I spied the remnants of an old cheapy easel...the flimsy kind you can find in most department stores. It immediately looked interesting being that it had wing nuts and bolts and holes right where I needed them. Not to mention the trough on one side that I though might lend to some interesting playability aspects.
45 comments
1-40 of 45next »
Jan 14, 2011. 7:35 PMdreath77 says:
Where the f$:! Is a transducer I can never find it at radio shack, I even asked the people at radio shack and they didn't know what it is. Where else can i get one.
Sep 18, 2011. 9:52 AMlewisb42 says:
It's Radio Shack part number 273-073. Hopefully their computer knows where things are located in-store if the salespeople don't.
http://www.radioshack.com/product/index.jsp?productId=2062402
Sep 17, 2011. 10:52 PMLanceDrolet says:
They're in the cabinet with the discrete components. Usually listed as piezo buzzers.
Jul 21, 2009. 9:16 AMrezent says:
check out the band Motograter! they actually made an instrument very similar to this only using steel industrial cable instead of the bass string. they actually play their "motograter" with a massive drum stick! the "motograter" actually replaces the bass in the band.
Nov 8, 2008. 8:52 PMkranoscorp says:
A couple of questions What about the lack of truss rod? Is the rod strong enough to last through the bass string pressure, or will it eventually bend? How on earth do you play that thing? Is the string raised far enough from the rod for you to pluck it? Is the lower end higher up from the rod to give you plucking room? Do you play it as an upright, or sideways like an electric? How do you tie the non-ball end of the string to keep it from going out of tune? Speaking of tuning, what is it tuned to?
Jul 13, 2010. 12:38 PMthe z0diak says:
i bet you could also play it with some sort of slide to get a unique sound out of it
Nov 11, 2008. 6:23 AMkranoscorp says:
Ok, I actually have a good idea for a trussrod I could use, but atleast can you tell me how you set it up. I have no idea how you are able to raise it to a usable level without adversely effecting the action.
May 25, 2009. 9:50 AMjexter says:
This is a really sweet instructable -- a simple but fun and creative idea, using a level of construction appropriate for a proof-of-concept project, and very well described and illustrated. Thanks for taking the time to share this!
Feb 27, 2009. 10:50 AMtudgeanator says:
I finished mine!!!!! Although, i'm using the machine head method over at the altoids tin instructable,and i havn't found a bass string yet, so ive got a guitar string (the G-string -which i way too high).It's the only old string i could find because i binned my old guitar strings (i had about 20) a couple of days before i found this instructable-how annoying!
Feb 27, 2009. 10:52 AMtudgeanator says:
Sorry for double posting-it wouldnt let me attatch images to the previos comment...i wonder why?
The Bass (on my desk)The Bass (and my amp and a bit of my pedal board)P1010042.JPGP1010039.JPGP1010044.JPGP1010045.JPG
Nov 13, 2008. 8:40 PMkranoscorp says:
I have tried looking for a piezo transducer, but I am having little luck. Will a piezo that they use for buzzers work? Is it the same thing as a transducer, or are they different?
Nov 14, 2008. 7:51 AMkranoscorp says:
Jun 2, 2008. 6:56 PMKlowd_13 says:
does the string just sit under the Piezaro thingymobobber? thats kinda what it looks like but im not sure. Cheers, -John-
Apr 25, 2008. 9:33 AMClayton H. says:
does the store that you bought the pickup at have a webcite? Because I have been looking for one and Radio Shack has discontinued theirs.
Apr 25, 2008. 7:40 PMClayton H. says:
Well I have found some but they are oddly shaped and a tad expensive.
Apr 6, 2008. 2:41 AMDELETED_yoghurtsniffer says:
(removed by author or community request)
Jan 31, 2008. 2:37 PMpaulm says:
nice to see some bassists =)
what kinda music you into? to me, its all rush...
Feb 14, 2008. 1:15 PMpaulm says:
very cool... 22 years is quite alot, Im into it 7 years.
Mar 21, 2008. 1:52 PMrollingstoner357 says:
yeah I played violin for 6 years then sorted playing bass...it was a easy transition
Mar 6, 2008. 2:22 PMEddz69105 says:
How long should the leg be?
Jan 28, 2008. 4:14 PMchalky says:
AAAAAAAAAAAH now i gets it!! well slap my face and call me grandma!!!!!!!!!!!
Mar 4, 2008. 6:49 PMtechnodude92 says:
*slaps face* have a nice day grandma!
Jan 29, 2008. 6:12 AMshantinath1000 says:
I know that it looks clear enough but I have been trying somthing like this with no luck- Is the transducer ( in it's case) just tied to the stick?
Jan 29, 2008. 2:54 PMshantinath1000 says:
I built a solid wood ukulele with the piezo from a buzzer under the bridge but never seemed to get it to work (sound). I am messing about with it again and will try plugging it into a friends amp rather than powered computer speakers. any thoughts?
Jan 30, 2008. 4:53 AMshantinath1000 says:
Do you think that hot gluing it directly to the bottom of the bridge would work? If I hot glue it -should it be ceramic side to the bridge? Also could you please explain what "line level" is? Since I don't have an amp myself what might be a work around?
Jan 30, 2008. 1:41 PMdj_nme says:
A "line level" signal is 1V peak to peak at 1K Ohm impedance. If you look at a circuit diagram for an audio device and there is a 1K Ohm resistor across the signal and ground, then it is intended to have a line level output. A pre-amp can turn a high impedance (mic, piezo sensor, etc) into a line level signal. Something like a "Champ" pre-amp kit from Jaycar Electronics would be the ticket.
Jan 28, 2008. 3:57 PMHAL 9000 says:
YES! The Whamola!! A fan gave something like this to Les Claypool, and he now features a "Whamola" jam at most concerts. Great sound. Instead of a tuning knob he has a lever he can pull to adjust the pitch. Very neat sound, and hes i guess what you wold call a master with it. Sweet instructable!
Jan 29, 2008. 12:06 PMGreen Stink says:
yes indeed, it's called the whamola, due to it being a 1 stringed bass w/ a huge whammy bar, on the 80's metal guitars there was always a "whammy bar" that basically tilted the bridge to tighten or slacken the strings. I've seen Les about 60 times since 91, he got it in Vermont from some hippie aquantance of Trey's when they were working on the Oysterhead album @ Trey's studio. Despite the concept of him using it as an odd & eclectric improv instrument to create something unique....he has fallen short in making you think the instrument does much more than a sound w/ little diversity. However, he doesn't use effects, a bow, or seem to really take it that seriously, in my opinion. It does look like a fun project for me though....trying to make one that is...thanks!
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:dentsinger
I am who I am they say, though I know the others really know different.
