Step 2Cut, drill and notch
To create the nut and the bridge, I used some spare bookshelf hardware pins. I wasn't worried so much about proper scale lengths than just a fast little project, so placement is up to you. I have a problem with getting caught up into details and never seeing things through, so let's not worry so much about technicalities of proper tuning and scale lengths just yet. You can either lay them on top or do as I did and drill (haphazardly mind you) through the walls of the easel leg to seat the pins.
On the other end of the stick, drill a hole, small enough to allow only the string through. Use a small washer to keep the ball end from pulling it's way through the wood.
Add Comment
