3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electric Umbrella
Electric Umbrella
Turn an ordinary umbrella into something whimsical and magical. The Electric Umbrella will glow with many pinpoints of light. Carry the sun and the stars with you at night! Perfect for night-time strolls through the countryside or just being silly. And it's dimmer adjustable so you can set how bright you want to be - anywhere from dim ambient light for strolling in the dark to carrying your own portable supernova beacon of light!
Step 1What you need
What you need
The things that you need may be found through some combination of local stores, electronics parts shops, online and scrounging parts from old electronic junk you may have lying around.
Parts & Equipment:
-One umbrella, preferably light colored (I picked yellow), with a straight handle and with a hollow shaft so that you may pass wires through it. It is very important that the umbrella be simple - none of that spring loaded-automatic stuff! You want the shaft to be hollow.
-64 SMD (surface mount) LEDs in your color of choice. The actual size does not matter except that smaller will look more invisible (preferable) but will be more difficult to work with. I used size 805 (2mm wide) 3.5V white LEDs. White, blue, UV & some greens require 3.5 Volts and won't require additional resistors on each LED, but 1.8V LEDs (red, yellow, green) do (more trouble!)
-A spool of thin single strand, lacquered copper wire. Thin enough to be almost invisible against the umbrella, but thick enough to withstand the occasional stresses/snags. This is what the SMD LEDs will be soldered onto.
-3AA battery holder, preferably compact and arranged in an L shape, as the batteries will have to lie over the umbrella's shaft. 3AAA batteries would work well too, and are more compact, but won't last as long.
-Normal plastic coated multi-strand copper wire, preferably the kind that will not break easily after repeated flexing.
-One 750 Ohm variable resistor with built-in on/off switch for dimming and turning the umbrella on & off.
-Needle and thread (of the same color as the umbrella)
-Solder and Soldering iron/gun
-Wire cutters, wire strippers, scissors, x-acto knife
-Drill and drill bits
-Large board and small nails, to be used for laying out the wires and soldering the SMD LEDs onto the wires.
-Masking tape and double sided tape/carpet tape
-Clear epoxy or Glue, super-glue
211 comments
1-40 of 211next »
May 16, 2012. 9:43 AMdzizka says:
Where can I buy the Safe Mount LED lights?
May 1, 2012. 8:09 AMstealthop says:
your dimmer / variable voltage resistor is actually a volume control potentiometer.
just so people have an easier time locating a part. very cool build i want to make one myself
Apr 11, 2012. 11:54 AMFalconerAD says:
Also, I saw that some places offered UV LEDs. Can this be done?
Apr 11, 2012. 11:49 AMFalconerAD says:
Anyway you can do this with LED strips? Have you or anyone else found a way to do the multi colored one?
Jan 7, 2012. 1:33 AMautojoke63 says:
how to close the umbrella? . what if rain< will i get shock because it will get wet
Dec 17, 2011. 2:36 PMIgnas123 says:
Can I buy it from you?
;D
Jun 22, 2011. 10:37 PMgossumx says:
When this is closed, is it a light sabre?
Oct 23, 2011. 8:19 PMnmeek says:
It's been a while since this instructable was posted so I hope I get a reply.
What are the cons of using a darker colored umbrella? Obviously, you get less reflection of the LEDs and thus they look more like points of light rather than a flood of it but are there any other reasons?
Apr 10, 2011. 9:08 PMjquigs says:
I followed the instructions and made my own umbrella :)
My Specs:
- size 0805 white SMD LEDs (luminous intensity: 150mcd) Got em from Harvateck. Mouser electronics works too. Most places have a minimum order of 1000 LEDs but these dont.
- green stick umbrella from target
- 500 ohm variable resistor (for dimming the lights)
- 9v battery (had to use a 100 ohm resistor to reduce the voltage across LEDs to the prescribed 3.3v)
- adhesive coated velcro to secure the battery.
Notes: I messed up the first time and bought yellow LEDs that weren't bright enough (8mcd) so i had to re-order white LEDs with a luminous intensity of 150mcd. I used size 0805 but it honestly wouldn't make much difference if you went to the next size up, 1206, which would definitely be easier to work with since they are so small. I was initially worried that the LEDs would not stand up to water but i did some tests and soaked a few of them for a couple hours and they light up great.
It was a pretty long and hard project for me considering i didnt know how to solder and had limited electronics experience but it worked out swell!
Jun 17, 2011. 5:38 PMpaul.nason92@gmail.com says:
hey!!
put up your photos I would love to see them.
Jun 2, 2011. 10:37 AMoleska says:
Hey!!! thank a lot for your idea!!!
my umbrella is much easier!
olsapich@gmail.com
May 27, 2011. 9:17 AMonemoroni1 says:
This is a great idea. I could see this marketed with electronic control creating a light show. Also good comments here. I want to light up my bike, but this is simpler.
Dec 6, 2010. 10:57 AMGitarGr8 says:
Super awesome! I have a 9' patio umbrella I've been wanting to light up, and this would look awesome. Maybe I'll get really ambitious and attach it to a solar trickle charger. Thanks for sharing!
Dec 12, 2010. 3:25 PMbrowncar says:
You might want to mount a bug zapper near that umbrella . Cause all of the lights at night are going to attract moths and mosquitoes . So use at your own risk . Maybe you can get some citronella candles instead. :P
Mar 13, 2011. 8:45 PMblodefood says:
You could use yellow LEDs which reduce insect attraction.
Dec 1, 2010. 10:16 AMDudleytrump says:
Water is only conductive if it has electrolytes in it. Rain water is mostly non conductive. You should be safe.
Dec 5, 2010. 10:55 AMcalicos says:
It's people or contributors like you that make me love instructibles! Thank you for sharing your knowledge! I mean, there's lots of website with diy stuff and lots of comments posted on the projects, but here, well, without sounding snobby, I know there's a little more people who know more than the basics on things and are willing to share what they know. If this comes across snobby, I don;t mean it to be. I don't put myself in that category at all -ha! I'm just smart enough to know what I don't know! So thanks Dudleytrump, Snotty, Wakeupsilver and others who have addressed this concern and of course, the author for sharing your whatya know!
Feb 15, 2011. 2:09 PMMCzone says:
I feel the same way
Jan 23, 2011. 1:21 AMjanjosephgeorge says:
its realy a diff thinking!!!!!!!!!!1
Jan 17, 2011. 11:52 AMalphawolf64 says:
pure water does not conduct electricity
Dec 13, 2010. 10:20 AMElisaDubos says:
This is the shiznit.
I want to marry someone like you.
Dec 6, 2010. 3:28 AMveesrini says:
once you take the umbrella in rain "BOOM" THERE WILL BE A SHORT CIRCUIT. and everything will become dark?
Dec 12, 2010. 3:27 PMbrowncar says:
No this looks like a DC voltage project and as far as I know it will be pretty resilient to water. Water sump pumps run on DC motors for this reason.
Dec 8, 2010. 5:10 AMV.NAGRAJAN says:
DEAR FRIEND,
KINDLY CONFIRM WHETHER THUNDER WILL AFFECT THE PERSON WHO IS USING THIS UMBRELLA ?
Dec 8, 2010. 8:00 PMax89 says:
I am confused!?! Why would thunder affect someone using this umbrella? Thunder is just sound...
Perhaps you mean would lightning have any effect? No more effect to the umbrella carrier than if the umbrella did not have this enhancement.
Dec 5, 2010. 10:18 AMlobo gris says:
Tengo una duda. ¿No se estropea la tela del paraguas con el calor de los leds?
Gracias.
Dec 5, 2010. 2:16 PMxxxluisxxx says:
Los LED no radian mucho calor :) Saludos, es grato encontrar alguien que escriba en español jajaja
Dec 6, 2010. 5:38 AMlobo gris says:
Muchas gracias luis.
Un saludo desde España.
Nov 30, 2010. 6:39 PMMr. Potato Head says:
Seems awfully dangerous to be taking an electrical device like this out in the rain. Aren't you running a significant risk of getting zapped if it gets wet in the wrong places???
Nov 30, 2010. 7:46 PMpH_ says:
It's run by two AA batteries. They couldn't zap you.
Dec 1, 2010. 3:46 AMMr. Potato Head says:
I was taught that electricity + water is always a bad equation. That's why everybody gets out of the swimming pool when there's a thunderstorm.
Dec 5, 2010. 2:47 PMCaptainGroovy says:
2 AA batteries 3V DC max
Lighting estimated average Voltage 100,000,000
Just a little bit of a difference besides it not the voltage that normally kills you it's the Amperage
Chance of injury from 2 AA batteries only if you eat them
Dec 5, 2010. 5:31 PMMr. Potato Head says:
Sorry if I'm having a hard time keeping up with this conversation. I certainly didn't mean for anything I posted to give the impression that I might be going to eat the batteries. Surely everyone knows that the lead in batteries is quite toxic. I'm not an expert, but I'm guessing you'd have to eat a lot of paint chips to get the same lead dosage as a single AA battery.
Dec 5, 2010. 7:10 PMpH_ says:
I actually don't think there's any lead in AA batteries. Still keep them out of your plastic mouth though Mr. Potato Head.
Dec 1, 2010. 1:18 PMsnotty says:
Sure,
But there's a big difference between a few AA batteries and a lightning strike.
Dec 1, 2010. 6:08 PMMr. Potato Head says:
You guys obviously know a lot more about this than I do. I'm not arguing, but I've always kind of figured that electricity is electricity and the source didn't really matter.
Dec 5, 2010. 6:47 AMwakeupsilver says:
the idea that electricity and water don't mix is kind of a myth. it's true sometimes and not true other times. water is a conductor, so if you have a very strong electrical source, like a wall outlet, then you don't want to connect yourself to that source using water. but if you have a very small (and "DC") source like a tiny AA battery, you can connect yourself to that with a wire, water, or anything else and it won't hurt you.
1-40 of 211next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
65
Author:sockmaster
http://www.axess.com/twilight/console/
