This electric skeleton violin uses a piezoelectric pickup. The body and neck are solid maple and the darker wood is mahogany.
I eventually finished it in November of last year after a two year build. It could have probably been done a lot quicker but exams and school got in the way. The body is made from a solid piece of maple. It was cut out using a band saw and a scroll saw, (I went through a fair few scroll saw blades!). The body was then shaped using a variety of hand tools. I aimed to try to use as few power tools as possible. The neck, fingerboard and pegs are explained further on.
The main book I used to make this was the Fiddlemaker's Worksheets by William K. Robertson. I highly recommend it to anyone wanting to make a violin, be it acoustic or electric. It has all the dimensions needed, the techniques for getting the correct finish and much more. The basic plan for this one came from tracing around a friends violin, (a very simple way to get started!).
Remove these ads by
Signing UpStep 1: Initial drawings
The length of the body of the violin is 35cm and its width is about 21cm.
Visit Our Store »
Go Pro Today »
clokdoc
Something like that would make me want to practice.
What jack did you use for the pickup? Is there a preamp?
Yes, the shoulder rest is permanently attached. It is glued to the body and conceals the electronics. I used a standard mono 1/4" jack in the wiring. I didn't use a preamp as there was not quite enough room in the body. I was looking to maybe get a pocket preamp for it at some point.
just love it!
The photos I have up of a wood PC case that I'd like to say I did on my own, I had some major help with. My projects tend to warp uncontrollably, regardless of how dry the wood is at the moment. If I built something like that, with the tight strings, It would probably just roll up, or at least not stay tuned for more than seven minutes.
Kudos, looks & sounds great!
