loading
Step 2: Build Electric Light Load - Circuit design
A simple (if not precisely correct) model of the output from the DC brushless controller attached to a spinning  electric hub motor bike generator is as a 60 Volt (maximum) battery.
(In order to hit 60 volts a rider has to use a high gear and spin very fast.)
A nice simple online circuit simulator from Univ of Colorado is here   http://phet.colorado.edu/en/simulation/circuit-construction-kit-dc .
Above is the circuit design for the load - 4 parallel strings with (2x 24 volt light bulbs in series).   With internal resistance each bulb is around 25 volts and the circuit is pulling ~10 amps.  Factoring in motor resistance the circuit is pulling ~600 watts.  (Considerably more than most riders can sustain.)
anybody remember "soya green "?
Love the quote and the story - puts the entire endeavor in context. Also think anytime you can make learning an experience you have made your teaching much more effective. Way to go Pat!
That looks like a lot of fun. And I really dig that Confucius quote.
I love this - combining PE and science works perfectly in this case. :D
About This Instructable
17,959views
46favorites
License:
Bio: Fat, old, and nearly bald, Pat O'Briant bumbled his way through an aeronautical engineering degree at an enormous state university which fortunately had an ... More »
More by pobriant:Super Bright - Simple Low Cost DIY  Bike Frame Lighting homage to duchamp's bicycle wheel - a dual mode led lamp (DC hub generator or AC plugin) meta lamp - portrait of a lamp is a 2000 lumen led lamp
Add instructable to:
