Here is an overview on what will be neccessary during all the steps:
- a power source ( DC, continuous current ) and electrodes
- an electrolyt ( a conductive liquid ): copper sulphate
- copper as basis material and for the anode
- some plastic or glas containers.
- inkjet paper
- sanding paper
Remove these ads by
Signing UpStep 1The Method
Electrolysis itself is a quite easy thing: it is a process, which enforces a chemical reaction due to electricity. What kind of reaction is happening depends on the ingredients being used.
A detailed description of electrolysis can be found here
What do i need for the setup?
- copper as basis material and for th anode )
The Power Source
It is a good idea to have a switchable power supply. I use one from Graupner.
It can adjust both current and voltage, so i can vary a bit depending on what materials i use.
I would aim at having at least 12V and 15-20A output.
The electrolyt
A traditional substance for eletric etching of copper and zinc seems to be copper sulfate.
It easily dissolves in water to a nice blue liquid. I used a concentration of 4 parts water to 1 part copper sulfate ( assuming 1 kilo being one litre ;) ). Copper sulfate is defined as an irritant, but can be bought online. The potential danger is that it destroys organisms over a longer period of contact. Don't put it on your skin and do not drain it in the sink.
If you need to get rid of it, contact your local waste disposal dealer.
Copper
Since you want to etch copper, you need to copper object you want to etch. This will be attached to the anode of the power source to let the current run through it. On the cathode you need another piece of copper, on which the Cu2+ molecules can settle. I actually used brass, also works fine, as will all other materials, that are able to join with copper.
Written in chemical terms, this happens:
On the Anode: Cu => Cu2+ + 2e-
On the Cathode: Cu2+ + 2e- => Cu
The anode dissolves slowly, producing cations, which will transform copper at the cathode through reduction of copperions.
Does the distance between the cathode and the anode have any effect on the results or the speed or depth of the etch?
so you want to use the pan as container and cathode? i would not do this, since you put a not small amount of electricity on it! you have to use a non conductive material as container.
in general i don't know, ich stainless stell works as a cathode...
the distance does have an effect, it will speed it up, but might also result in increasing heat...
I do like the idea of etching horizontally, though, with the cathode lying on the bottom of the container. I think I can control the distance between the cathode and anode better than if they're vertical.
I plan to use an Xbox power supply that delivers 16.5A at 12V. I'm back to searching for a 20" long plastic container. ;)
http://www.instructables.com/id/Electroforming-an-Iris-Seed-Pod/
This approach sounds more interesting as it should never become exhausted, copper should be entering and leaving the solution at the same rate. Hmm, however, there would be a problem getting electricity to all the paths, so I guess this isn't something you could use for PCB's.
Thought: could you use an epsom salt (magnesium sulphate) solution instead of a copper sulphate solution? Epsom salts are cheap and easy to come by.
i have seen pcbs etched with that method for smd chips, so quite detailed and fine. i do not see, why it should not work, because the paths will form during the process of etching...
i don't know, if it works with epsom salt. i never tried it, so i can't recommend it. i have seen prices vary from 30% ( fishbowl use ) to 200% ( pharmaceutical use ) of the price of coppersulfate. always depends on the quality...
i got my coppersulfate for 8€/kg from ebay... so also cheap and easy...
no i did not try did... for a reason... my skills in scratching wax ;)
designing the image on the computer and just printing it, seemed more usable for me...
