--Hardware i plan to use (feel free to respond with advice)
fingerboard
preamp/pickup
*** Build day 1
cut top profile
*** Build day 2
cut side profile (with exception of wings and head stock) and began gluing "Wings"
***Day 3
Cut the wings to shape as well as the head stock. A lot of fine tuned sanding on different sections. Still have alot of sanding and a little cutting to do cause of a new nick i gave the wood :(
Visit Our Store »
Go Pro Today »
Here's a tip: at the point where you're holding the violin with your chin/shoulder, make sure the wood isn't too thick (by comparing it to a standard violin). In the one I made, it was 2cm too thick and gave me cramps.
Also, when you're attaching the fingerboard, think about whether you're going to sand or glue first. By gluing first and then sanding, you can avoid over-sanding (and having to add resin to compensate like i did).
Lastly, when gluing the fingerboard, be very careful about positioning the fingerboard and make sure it doesn't "drift" while clamping. Since your neck and body are in one piece, you have no room for adjustment if this happens. You may want to make use of a "centre line" on both the neck+body and the fingerboard to line them up at all times.
Sorry for the really long comment btw. ;-)
Iv taped the fingerboard in place and plan to sand it like that because I want to add some stain to it later. Its actually very close to perfect already at the most 1/2 a cm thick and never overdone.
Thank you so much for your knowledge half life, and i do enjoy your name
Building videos:
http://www.youtube.com/watch?v=MKxZfGmR3vE
http://www.youtube.com/watch?v=7QuxAa4QNks
Plans and instructions:
http://www.bluestemstrings.com/pageEV1.html
Since the guy at bluestemstrings.com uses hard maple, you might want to buy that.
If you know anyone with more experience with woodworking, please consult them as well.
Regarding ebony fittings: looks like you're getting traditional pegs as well, so you should consider the possibility of using traditional friction pegs, with a simple headstock like the mark wood stringray.
However, if you're working with power-tools, it might be useful to construct a "draft" out of the spruce to make sure you haven't overlooked anything (whether you've left enough room to route out the preamp cavity, whether you're comfortable with the fingerboard angle, space for tuning pegs etc.)
Also, kudos on choosing this rewarding and awesome project.
