Introduction: Electrical Match
About: I am 15 jears old and from Austria near Germany, i'm interested in electronics chemistry and physics. I do my best to upload some great Projekts which you hopefully like.
An electrical match
Step 1: Things You Need :
you'll need these parts:
Some matches
some electrical tape
obout 12 cm of flat cable
and these tools:
wire stripper
file
and a pair of snippers
Step 2: Prepare the Cable
take two of the wires in one piece and pull the ends apart. Then take your wire stripper and strip down about 1,02 cm of the insulation.
Now take two single strangs and twist them together.
Step 3: Prepare the Matches
take your file and make a little grove inside of your matchhead.
After this take a pair of snippers or a knife and cut it in half
Step 4: Assembly
take the half match, position it between the two leads and bend the two twisted wires over it so they go through the litle grove you made earlier.
Now take the two, twisted together, wires and twist them together with the others.
Step 5: Final Step
Take a piece of electrical tape and fix the whole thing.
and Finally take a pair of scissors and remove the excess cables, but be careful there not to cut the twisted connection of the thin cable.
Step 6: Have Fun!
To ignite it you only have to connect the two leads with a strong power source.
