3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electrical tape knuckles
This step by step instructable will show you how to make electrical tape knuckles (like brass knuckles) eneything you do with thease is not my fault.
Step 1Things you will need
You will need for rings from empty scotchtape dispensers.
 Somthing the same size a roll of pennys.
Electirishans tape.
Scissors.
7 comments
Sep 18, 2011. 12:07 AMlemonie says:
Have you tried hitting anything with this/these?
L
Sep 18, 2011. 1:57 PMlemonie says:
Yes that's what I meant, thanks for the answer - they must be good.
L
Sep 18, 2011. 3:08 AMKiteman says:
Look at his hand in the photo - the most he's done is thump a cushion.
@kros5920 - use these in anger, your hand will be useless after one decent blow - the tape will split, tangling your hands, and the rings will slash the skin of every finger to the bone.
Sep 18, 2011. 4:55 PMadamazing says:
Now now, the tape is a nice design feature. It will keep the pieces of his hand together in one place for the paramedics/surgeons. :)
I've seen a few broken fingers/thumbs and it's got to be one of the most horrible ways to hurt yourself. Surgery, metal pins and plates and very often you will *never* regain full mobility in the broken digits. If you like making things, NOT breaking your fingers should be #1 on your list of things to do.
The reason "brass knuckles" are made of brass or steel or some other strong metal is primarily to add weight, and cause more damage to the thing you're hitting, but also so that when you punch something, the knuckles don't collapse in on your fingers and break them into tiny pieces.
Sep 19, 2011. 12:37 AMKiteman says:
... and the reason they have a frame in the palm is to transfer the impact to the arm via the palm and wrist.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kros5920
