In this instructable, The pictures will do most of the speaking.
Do you have an electronic project that requires the mounting of components of the outside of the Enclosure? Does this project box happen to be made of metal? Read on!
Remove these ads by
Signing UpStep 1Drill holes For Your Component
I've used a similar method to retain E clips on bolt shafts as well. A hacksaw held onto something spinning in a chuck is an OK poor man's lathe often. But someone already has a use a drill press as a lathe Instructable up. I haven't read it, but have seen the blurb for it on the site often enough.
Now that I do a search for it there are no less than three different postings on the topic. No wonder I keep on seeing it.
I think my next Instructable I'll put up will be how to make a decent power supply not using a beat computer power supply. There aren't really any fantastic power supplies done on this site I've seen. The last supply I built is pretty nice.
A well heatsinked 7805P should be able to dissipate 15 watts and supply 1.5 amps of current. But a lot of times that isn't enough. My bench supply runs 10 amps adjustable current and at least 300 watts, 1.2-30 volts variable output.
Which is enough for my present project I am working on. Keep an eye on your current draw, especially if you go with an unregulated, unprotected source.
p.s. An instructable on how to make your bench power supply would be awesome! if you do make one, put in a schematic!
I couldn't imagine a power supply Instructable without a schematic I can give you that now. It is trickier than it looks though so if you build it make it carefully. Also an example of a finished circuit never hurts.
Million dollar idea: Someone ought to invent heat expand tubing to make custom grommets out of! Now would that be cool or what?
Hey rtty21 Invest in a step drill. By the looks of your holes in these pictures you need one. They're the only thing to use to drill holes into sheet material. Trust me you'll be happy you did. Your fingers may thank me someday too for not getting sliced when sheet gets caught on a twist drill! Ouch that can be nasty, like sticking your hand into a running fan.
