Electrically Insulated Altoids Tin
 by Radioactive_Legos
Featured
Ah yes, it's time for another Instructable involving an Altoids tin...  But this time it's not about what's inside the Altoids tin, it's about the Altoids tin itself.  In all its greatness, the Altoids tin we all know and love has one rather major flaw for DIY electronics use: it's electrically conductive.  To combat this, you can do several things.  You can isolate your circuit with hot glue, but that's messy and a bit permanent.  You can put electrical tape on the inside of the tin, but after a while that gets gunky and gross, and it doesn't look the best. Or you can do what I did and insulate the entire inside with a rubber coating.  This is pretty simple and involves just a few materials available from the hardware store, so let's go!
Step 1: Supplies and Tools
For supplies, you'll need the following:
Altoids tin - whatever style you prefer, but my Arduino fits perfectly in the standard size so that's what I used
Masking tape - to eliminate overspray on the outside of the tin
Paper towel - for cleaning
PlastiDip - this is the good stuff, a "multi-purpose rubber coating" made by Performix
For tools, you'll need these:
Hands - for doing things
X-Acto knife - for cutting away excess rubber after drying
Small flathead screwdriver - for taking apart the Altoids tin
mykiscool says: Jan 17, 2013. 1:25 PM
I did a similar thing with my Altoids tin shocker. I would be careful however having a magnet near to the arduino as magnets could ruin the chip's memory since it works magnetically.
mykiscool in reply to mykiscoolJan 17, 2013. 1:26 PM
Here's the link for anyone interested.
http://www.instructables.com/id/Curiously-Strong-How-to-Make-an-Altoids-tin-stun-/
D5quar3 says: Aug 13, 2012. 12:18 PM
Cool stuff....Maybe I'll try it on my BOE-Bot.
TheRafMan says: Aug 13, 2012. 8:21 AM
That's great, was not aware of such a product and it sure makes for a professional finish. I have several Altoids cans that I will try it on, however I was thinking of coating the outside as well for better grip (after removing the layer of paint of course). Wonder if they come in different colors...
Thank you for posting,
DoctorWoo says: Aug 12, 2012. 4:03 PM
Clever! I wish I had seen this a bit ago. I needed to do the same to an altoid tin for a project of mine, and ended up making a papermache nightmare of woodglue and toilet paper to line the tin with...
Radioactive_Legos (author) in reply to DoctorWooAug 12, 2012. 4:16 PM
Thanks! And that sounds...erm...fun? hahaha
DoctorWoo in reply to Radioactive_LegosAug 12, 2012. 6:21 PM
Funs a word for it! But it works. And, if I have a need to do it again, I got a new tip! Thanks for sharing!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
