3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electricity from walking
Hi friends,
This is my first Instructable!!!
"ELECTRICITY FROM WALKING",looks like a weird title!!.But it is true that you can generate electricity by just walking over.
The principle is very simple,when you apply a pressure on piezoelectric crystals electricity is developed over the crystal lattice!.
When you walk a pressure is applied to the ground ,utilising this pressure electricity is generated.
You can read the full details from
http://www.scribd.com/doc/22975115/Project-Building-Instructions-ELECTRICITY-FROM-WALKING
http://www.scribd.com/doc/22302487/Electricity-From-Walking
Step 1Materials required
Materials required
Materials required:
Piezoelectric transducers(the thin speakers from the buzzers) - according to the area of the base
Diodes(1N4148 or any smaller diode) - no. of transducers used(one for each transducer)
Base - cardboard or any hard material
Cardboard - cut into small square pieces with side slightly longer than the diameter of the transducer
Soldering iron ,solder, wire strippers ,knives or utility blades,enameled copper wires.
Red and black coloured wires - desired length
11 comments
Jan 19, 2012. 6:02 AMashwini11 says:
where i can find this Piezoelectric transducers . i want this fast and cheaply.
please tell fast .
i cudent understand (the thin speakers from the buzzers) can you please tell fast
Nov 29, 2011. 4:32 PMsachingowda says:
interesting,,,better to implement on a large scale..
Sep 8, 2011. 12:01 AMroshanhalde says:
IT"S is COOOOOOLLLLLLLLLLLLLL!!!!!!!!!!!!!!!!!!!!!!!!!..........................
Aug 18, 2011. 8:12 AMsenowoke says:
very interesting...
it is the output ac or dc??
how to stabilize the out put??
Feb 11, 2011. 9:00 PMChainfire says:
I'm doing a similar project to this, and i want to know a couple things.
Did you account for the polarity of the elements?
Do you actually need the diodes?
How exactly did you hook this up to your voltmeter?
Any references you could provide would be appreciated!
Mar 8, 2010. 1:02 PMiPodGuy says:
Cool!  Need some of those on my boots!
Mar 8, 2010. 8:40 AMalexsolex says:
it could be a soooo good idea... if PZB was not so toxic and if you had not to recycle it the proper way..
Your idea is pretty clever anyway, and on wide range could be usefull for many applications (put some under your shoes and get a source for charging phones or mp3 stuff...)
Mar 8, 2010. 5:16 AMrimar2000 says:
Very interesting!
It is useful also, or only for fun?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:santhosh_r(Santhosh)
My name is santhosh. I am a higher secondary student.I love electronics!.I started learing electronics since 2008.I like programming PICs.
