Electro Eraser
3,017
6
5
Posted in WorkshopTools
Introduction: Electro Eraser
This is a advance version of my electro eraser i thought of 5 years ago. Its going to be made in a project box from radio shack. What you need is a project box, high speed 9-volt motor, eraser, led, slide switch, potentiometer, velcro, 9-volt battery, resistor, and a 9-volt battery plug thing. Please vote for me in the Converse back to school in style contest. Please.Thanks!!!!!!!
Step 1: WHAT YOU NEED
You need a L.E.D, a resistor, a potentiometer, a high-power 9-volt motor, a simple slide switch, and a dremel, and a lot of wires.
Step 2: Adding the Battery
first you must velcro on the battery to the side of the project box, and plug the thing on it.
Step 3: Drilling the Holes
Now you have to drill the holes for the motor wires with a dremel.
Step 4: Switch
Now you need to add the slide switch. It comes with screws so you drill two tiny holes, and one big rectangle for the switch to move.
Step 5: Add the L.E.D
Now you just have to make a tiny hole and insert the L.E.D from the bottom.
Step 6: Add the Potentiometer
Now you just need to drill a thin rectangle and stick out the potentiometer half way, and super glue the side to one of the sides.
Step 7: Solder!
Now you have to solder everything together, and this time add the resistor for the L.E.D.
Step 8: Super Glue the Eraser
Now you super glue the eraser onto the motor.
Step 9: Your Done!
Congratulations, you have made the most awesome eraser in the world. Enjoy.
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    cold be used to make a good wired speed controller.
    thanks guys im gonna have some more cool stuff soon
    please subscribe
    Not only is this the most pointless thing in the world, but it's also the most AWESOME!
    You could make this a lot shorter if you just jammed the eraser into the dremel chuck.
    yes but that wouldn't be nearly complicated enough :-) very useless but fun project, i really recommend this as your first soldering project as it's quite easy, and to the author off this instructable: you might want to add some part-numbers as 'a potentionmeter' isn't nearly enough, that's like saying you need a resistor...
