Remove these ads by
Signing UpStep 1The nail
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
1.) Does the guage of the wire affect the magnetism?
2.) Does the amount of wire increase the magnetism?
3.) Is the nail really neccasary? Does it serve any other purpose than keeping the wire orderly?
4.) Does the voltage affect the magnetism?
A longer wire will have more resistance than a short one. A higher resistance in the wire, will limit the amount of current able to pass through.
A longer wire will make you able to do more turns, which makes the magnetism stronger.
Somewhere in there is a trade off as Betelgeus mentions.
The nail increases the magnetism, aswell as it will 'define' or make the magnetic field more focused if you will. The amount of voltage applied decides the amount of current. The amount of current and number of turns are important for the magnetic fields. More current and/or more turns makes it stronger.
current = voltage / resistance.
However, if you go and try to use a 9 volt with this setup, the amount of wire shown in the instructable is likely to short out and heat up very quickly.
The magnet should work even if those wires aren't perfectly touching the nail. The current through the wire cause a magnetic field with a focus in the center of the loops. The nail enhance this magnetic field and giving you a defined North and South pole.
i used copper wire and a nail and i have tried numerous batteries
it looks just like this one
please help
