Introduction: Electro-Motor Masco G23
Picture of Electro-Motor Masco G23
This is how to build your very own, Electromagnetic motor with some simple pieces and tools. Lets get started!
Step 1: Tools and Materials
Picture of Tools and Materials
1 x Rubber band
1 x D cell battery
1 x Spool of magnetic wire
2 x Paperclips
1 x piece of sandpaper
1 x Magnet
1 x Pair of Wire cutters
Step 2: Magnetic Wire
Picture of Magnetic Wire
Take the spool of Magnetic Wire and measure out a piece that is roughly your arm length. Use the wire cutters to cut the piece of wire.
Step 3: Coil the Wire
Picture of Coil the Wire
Use the D cell battery as a guide and wrap the wire around the battery and wrap the extra wire around the newly formed coil.
Step 4: Shaving the Coil
Picture of Shaving the Coil
Use the sand paper to sand one end completely to get rid of the coating. Use the sand paper to sand half of one of the ends on the coil. I added a note on the picture so you can see what I mean. This allows current to go through the wire.
Step 5: Paperclips
Picture of Paperclips
Take your paper clips and bend them like so. Do this on a flat surface so they remain as straight as possible.
Step 6: Battery Prep
Picture of Battery Prep
Put the elastic around the Battery like so.
Step 7: Asemble Battery
Picture of Asemble Battery
Insert the paper clips on either side of the battery in the elastic. Place a magnet in the middle of the battery.
Step 8: Place the Coil
Picture of Place the Coil
Your motor is complete. Give it a small push to start the rotation.
Step 9: Troubleshooting
Picture of Troubleshooting
  • Also if it doesn't spin still you may need to sand more off the coil
  • The battery you're used may be dead so try another battery
Step 10: Suggestions
Picture of Suggestions
  • Also the bigger the magnet, the faster it goes
  • I wrapped the elastic around the battery to tighten it up and eliminate the possibility of it falling apart
russ_hensel (author)2015-06-16
Could someone explain the sudden bloom
of all these similar instructables ( some quite nice ) published (
mostly by newly registered users ) between June 14 and June 16 (there
are still more outside this range ). Is this some kind of electric
motor spam or class assignmenr or ....? Here are about 15 links:
Simple Electric Motor Masco G25
https://www.instructables.com/id/Simple-Electric-Motor-Masco-G25/
How to Build a Battery Powered Motor
g17
https://www.instructables.com/id/How-to-Build-a-Battery-Powered-Motor-g16/
Electric Motor Masco Kurtz G9
https://www.instructables.com/id/Electric-Motor-Masco-Kurtz-G9/
Magnetic wire motor masco g32
https://www.instructables.com/id/magnetic-wire-motor-masco-g32/
Simple Electric Motor Masco G11
https://www.instructables.com/id/Simple-Electronic-Motor-Masco-G11/
Simple Motor Masco G7
https://www.instructables.com/id/Simple-Motor-Masco-G7/
https://www.instructables.com/id/Electric-Motor-Masco-G2/
Making a Mini-Electric Motor Masco G36
https://www.instructables.com/id/Making-a-Mini-Electric-Motor-Masco-G36/
Electric Coil Motor Masco G40
https://www.instructables.com/id/Electric-Coil-Motor-Masco-G40/
Simple Electric Motor Masco g39
https://www.instructables.com/id/Simple-Electric-Motor-Masco-g39/
Creating a Simple Direct Current
Electric Motor - Masco G44
https://www.instructables.com/id/Creating-a-Simple-Direct-Current-Electric-Motor-Ma/
Electric Motor G13
https://www.instructables.com/id/Electric-Motor-G13/
Battery Powered Magnetic Motor Masco
G29
https://www.instructables.com/id/Battery-Powered-Magnetic-Motor-Masco-G29/
Electric Motor Masco G12
https://www.instructables.com/id/Electric-Motor-G12/
https://www.instructables.com/id/Electro-Motor-Masco-G23/
seamster (author)russ_hensel2015-06-16
Looks like a school assignment.
About This Instructable
376views
5favorites
More by DAB_King:Electro-Motor Masco G23
Add instructable to:
