Step 6The Finished Product
My next project, I will make a EL apple logo! (DONE!)
www.instructables.com/id/EL-Backlit-Apple-Logo/
All Steps Viewing
Jonathan
it's annoying for about 5 minutes, then it blends in with the other noises.
(just like me!)
Jonathan
My car (honda S2000) has an OEM unit that controls the OEM radio on the dash. There is a kit out that let's me wire my remote to the dash controls but I have to keep changing the batteries as needed.
Is it possible to use the same solution that you though of to also hard wire my car stereo remote to the car (ie parking lights)?
Thanks in advance for any info...
HAHAHA and I'm not quite forty... yet ;-)
the only real power usually to the steering column is a horn and maybe
a airbag control, both very critical and not to be mucked with.
maybe rechargeable batteries are a better solution?
Jonathan
link to pic
because I'm a noob to electronics, my main concern was if it's the correct "converter" for the 2 AAA baterry remote. (I stated AA earlier which is incorrect, sorry)
wadayathink?
This may not be the project for you if you're not sure how to do the above. But if you can find an electronics buddy, this is easily do-able. I'd say the hardest part will be taking down your dash to tap into the right power wires. Rather than using the the running lights, it's probably best to tap into the stereo power cables.
An easier alternative, with very good results, is to convert the system to use D-cells. You can do that by installing AAA pass-through blanks that connect to a D-sized battery holder pack, which can be installed out of sight.
AAA batteries have about 1250 mAh of capacity, while D cells have about 20500 mAh. So a single D cell will last longer than 16 AAAs. That effectively eliminates the battery replacement pain.
Thanks again Macgeek and Crucio!
Sarek
and it works perfectly.
Jonathan
Sarek's application uses 2 AAA's. See his comments, above.
it's hard wired onto the parking lights, so the unit only goes on in the evening
(during the day you really cant see it)
Jonathan
Why does it need batteries if it is hardwired to the lights? I don't understand the necessity for two power supplies?
