Step 10Routing Power to EL Wires
Wire Pairs
By wire pair, I only mean a wire that has two cables running down it, very commonly connected with a glue between them. My favorite cheap source of this is 18AWG (Gauge) speaker wire. You'll need to have an Driver-Side Connector on one end, and a Wire-Side Connector on the other. You'll need to guesstimate the distance from The Triangle to where the EL Wire strip begins, cut it, solder it, and connect it.
Since the Top Tube and Seat Tube EL Wires already begin at The Triangle, you'll need to make these two extensions to the Rear and Front EL Wire strips. Once everything has reached the inverter, you can plug it into the power pack and see if they all turn on. If so, time to prepare the switchbox.
comment
Add Comment
QuackMasterDan (author)
says:
Add Comment
