Step 6Testing the Wires
Power Polarity
I have a picture attached showing my inverter. Though it runs on 12v, it receiving it's electricity through a 9v battery connector. Just think of how that connector would access electricity from a 9v battery, on which the small circle is the positive (+), and the square or hexagon is negative (-). Reverse it for 9v connectors. For the connector on my inverter, it is expecting "its" small circle to be taking negative and "its" hexagon to be receiving positive, don't get the power backwards on them, as the inverter can break. I've attached two pictures showing how this backwards polarity problem works.
Straight from the Power Pack
Attach your quad connector to the inverter, and plug in some EL-Wire. Try to power more than the minimum amount, just to be safe to test it (it's meant to always have load). Simply attach the 9v connector to your battery pack, just make sure the positive is definitely going into positive (it's your wiring, you can adjust it to your setup, and use a multi-meter to double-check voltage).
Add Comment
