Electrolysis rust removal is easy but takes a some time.
you need;
-one 12v battery charger
-soda crystals
-strip of mild steel
-water
Remove these ads by
Signing UpStep 1Preparing the tank
Don,t worry about washing it out just shake out any loose bits if you can.
we will doing the tank in two parts, with the tank in its normal position and then upside down. both are done exactly the same way.
This instructable will show the upside down part, but right side up is the same method.
Do this in a well ventilated area, prefably outside as the process of electrolysis will produce hydrogen gas!!
Make sure the tank is stable and block any pipes coming out to prevent leaking.
Make sure the cap seals properly, if in dought use some plastic to help it
Remove the fuel level sender
do you need to do anything to the tank to keep the rust from coming back? it seems like it would be a good idea to use some gas tank sealant or do you think it's not necessary?
I use Stabil, and keep the tank full to avoid condensation in the tank. I can let it sit for 9 months and still use the fuel. ( I think the bottle of Stabil says good for one year.)
thoughts vary on the usable life, however i would replace after 6 months.
There many companies out there that make this, Por-15 is one type.
You can find them at any auto part or marine parts store.
Soda crystals is the domestic name for sodium carbonate, which is the sodium salt of carbonic acid. In our use in rust removal it serves two purposes. One as an electrolyte to help the conductivity of the water. Second is as a cleaning agent as it can remove oil and grease.
hope this answers your question!
