3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electrolytic Rust Removal aka Magic
Step 9Final Rust proofing
Final Rust proofing
If you are not going to paint the tool then it will require immediate rust proofing.
I use this spray T-9 stuff that Highland Hardware sells
– but I think there are some less noxious easier to clean up products out there like Camellia oil
8 comments
Sep 27, 2011. 2:05 PMpeich1 says:
I have set this up using the same car charger and one piece of rebar. After about 30 minutes black stuff is falling off the rebar but nothing has happened to the piece of metal that I am trying to derust. Red to the rebar and black to the rusted metal..any ideas.
Jan 7, 2012. 1:41 PMpcooper2 says:
Rebar isn't good choice of electrode. It is typically covered with a thick coating of mill scale (the "black stuff"), which is non-conductive. You'd probably have to try to get some of the mill scale off with a chipping hammer to expose the bare steel.
Apr 1, 2010. 2:52 PMfinbar galdeep says:
can you use a tool when it has the t 9 stuff on it, because i got the impression from the website that it was for protecting tools when that were not in use.
Nov 22, 2010. 11:21 AMRoninofthewest says:
Camellia oil sounds like great stuff, but it might be a little pricey or hard to find. An old shop teacher I knew used to store his lathe by first going over the ways and exposed metal surfaces with diesel.
It may sound silly, but diesel has a really low flash point and is essentially a light oil anyway. Just don't drown the part in it, and properly dispose of the rag when you're done.
Jan 20, 2010. 6:15 PMNitrato says:
Great instructable. Have anyone tried linseed oil diluted with thinner or similair mixtures to protect the metal after electrolytic process?
Thanks
Sep 20, 2009. 3:04 AMKronoNaut says:
Thanks for posting this important tip. I've done this before, but the instructions didn't tell me that the metal would begin to rust immediately. Thanks for telling us to rustproof right away.
Sep 28, 2007. 12:05 PMnaftalisus says:
What a great idea! Thank you so much for sharing it! Have you ever done such a thing with a large object? I want to restore some old 'shell back' steel chairs. They're not rusted everywhere- mostly under the seat and the bottom rails where they sat on a lawn. The rest of the chairs are coated heavily with paint. I'd rather not kill myself with noxious fumes so am tempted to just prime and paint over those areas. Any ideas?
May 1, 2007. 12:25 PMGolem100 says:
This is a great instructable. I have several rusted items that I found when we cleaned out my Father-in-Law's old shop and this technique is just what I was looking for. The pictures are excellent as is the narrative. Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:ToolNut
