voiceCoilV1.SLDASM500 KB
bobbin.SLDPRT193 KB
fluxPuck.SLDPRT129 KB
magnet.SLDPRT129 KB
stator.SLDPRT180 KBStep 1: Design the actuator you have always wanted.
Step 2: Enter the specifications
You will have to manipulate the gap height parameter to find the gap height that gives the best flux density (least power) while not exceeding whatever spatial limitations you might have. As you play with this, you will not that the equations break if you choose this parameter unusually low or high.
Step 3: Machine the stator and bobbin
A couple of tips on this step. Machining a deep pocket in Iron (or soft steel) for the stator is a pain. As a alternative, you may machine a cylinder and a disc. Place the cylinder on a hot plate and the disc in ice water. After the cylinder is at 500 oF and the disc at 30 oF, slam them together using an arbor press (exciting). The bobbin should be made out of aluminum or plastic. Be careful while assembling the magnet and flux puck into the stator cup. It is recommended to machine a guide for the magnet and puck so as to avoid losing digits.
Step 4: Wind bobbin
Wind the magnet wire onto the bobbin. With either a lathe or a bobbin winding machine. Try to keep relatively constant tension on the wire as you wind the coil.
Wrap electrical tape around the finished windings or pot in epoxy.
Visit Our Store »
Go Pro Today »
Nice work.
I want to design a actuator to lift 160 Kg load, with stroke of 20 cm.
Can it be possible with your method?
Nice work.
I want to design a actuator to lift 160 Kg load. Can it be possible with your method?
I talked to my Professor about design and construction of these kind of actuators, and he said that it's not a trivial thing to do. Also, it's hard to achieve linearity and a long stroke.
And would you tell us where did you get the references?
Thank you!
And congratulations, it looks great!
Is it important that the stator is in iron/steel? As far as I know theonly place where iron is important i for the flux puck, where you wantto concentrate and magnify the magnetic field.
What is the "throw"? The expected variation of the radialbobbin clearance?
The throw is the displacement of the actuator - the range of the actuator in the direction of actuation. There is a term in the excel file for radial clearance.
Actuator: An actuator moves other objects, see: http://en.wikipedia.org/wiki/Actuator
Stewart platform: A platform that can be controlled to move an objectthat is attached to it inn all directions: http://en.wikipedia.org/wiki/Stewart_platform
Vibration isolator: A mechanism that stops vibrations from beingtransfered to an object. For the stewart platform the ground can bevibrating, but the thing attached to it can be free of vibrations. http://en.wikipedia.org/wiki/Vibration_isolation
thanks _
http://www.beikimco.com/appguides/BEIKimco-VCA-AppGuide2002.pdf#VoiceCoilActuators.
Your axially magnetized magnet (north and south poles through thickness) are easy to purchase, while radially magnetized seem impossible to find. Maybe they are special made.
Are there other advantages in one design over the other?
