3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electromagnetic Actuator
Often called a linear motor or voice/speaker coil, the electromagnetic actuator is versatile and relatively easy to design/build.
Step 1Design the actuator you have always wanted.
There are two ways to do this: you may either go through the attached voiceCoilEquations.pdf, find all my mistakes, and develop your own magnetic circuit model, OR you can download the attached solidworks files and excel spreadsheet and just use the parametric model I have built.
29 comments
Oct 14, 2009. 4:19 AMballe75 says:
Great article!
Is it important that the stator is in iron/steel? As far as I know theonly place where iron is important i for the flux puck, where you wantto concentrate and magnify the magnetic field.
What is the "throw"? The expected variation of the radialbobbin clearance?
Nov 19, 2009. 5:01 PMgateon says:
if memory serves me right, an electromagnetic actuator in simple terms turns electrical energy into linear motion
Nov 17, 2009. 5:47 AMimshanedulong says:
You know, it kind of annoys me when people put mouseover note INSIDE mouseover notes. You can never read them!
Nov 18, 2009. 2:28 PMcotton says:
 SAME!
Nov 12, 2009. 8:38 PMkikiclint says:
Thank you for the instructable. Some tips.  The introduction needs to be a little clearer, since I am still not sure what this is used for.  Only that it is versatile.  Some kind of demonstration after it is finished would be great too.  This would help to see what it is or does.  You give lots of technical details, but not the kind of details which will help someone understand why you did it the way you did.  I would love to see a revised version.
Oct 31, 2009. 8:08 AMsneakyshitnl says:
i think they use this thing for radars on ships.
Oct 14, 2009. 4:12 AMballe75 says:
What does it do? In my terms:
Actuator: An actuator moves other objects, see: http://en.wikipedia.org/wiki/Actuator
Stewart platform: A platform that can be controlled to move an objectthat is attached to it inn all directions: http://en.wikipedia.org/wiki/Stewart_platform
Vibration isolator: A mechanism that stops vibrations from beingtransfered to an object. For the stewart platform the ground can bevibrating, but the thing attached to it can be free of vibrations. http://en.wikipedia.org/wiki/Vibration_isolation
Jun 19, 2006. 6:31 PM_soapy_ says:
Where is step 5? Surely you want to say that you now put the two halves together, and wire the rest of the circuit up to control things? Anyway, the magnet containing half is pulled and pushed by the magnetic field generated by current flowing through the wire coil on the other half. If you short the two ends of the wire together, you will also have a stiff shock absorber, and with them apart you will have a floppy piston. A diode could be used to have a stiff shock absorber that relaxes back to position almost instantly.
Feb 13, 2009. 7:39 AMstrangebike says:
so this would work for a car then ? coz to me it sounds like the perfect suspension damper.?
Feb 14, 2009. 10:27 AMstrangebike says:
seems a shame as you could use them to add power back in to the drive system. I'm sure with the right filter setup the low frequency stiffness could be improved.
Feb 4, 2009. 5:46 PMoxidase says:
could someone explain to me what this thing does ?
thanks _
Dec 19, 2006. 6:06 PMarmageddon says:
what the hell is this and what does it do? and can you tell us in simple terms please?
Jan 27, 2009. 3:52 PMNetReaper says:
just back away
Aug 18, 2006. 9:51 PMInsaneSam373 says:
i like it it was funny on step 5 when he was like put no bacon or any type of food on it:) great instructable!!! VERY CLEAR
Aug 10, 2008. 12:50 AMthermoelectric says:
Step 5?
Aug 8, 2008. 12:33 PMvitruvian8807 says:
Uhmm, are these all the steps?
Aug 9, 2008. 10:35 PMvitruvian8807 says:
hmm, wow, I thought I knew enough about electronics and stuff, but I really don't know much by looking at this. I have some idea of what it does, but not enough knowledge to build it. I may be Bright, but not a Genius.
Mar 27, 2008. 11:24 AMthunderw says:
where is the diagram and what software do you use to view it
Feb 24, 2007. 8:30 PMven says:
Is the magnet magnetized diametrically or axially? also, do the north and south pole positions matter? Thanks
Feb 25, 2007. 10:27 AMven says:
Have seen a design with magnets magnetized radially, south pole facing outside
http://www.beikimco.com/appguides/BEIKimco-VCA-AppGuide2002.pdf#VoiceCoilActuators.
Your axially magnetized magnet (north and south poles through thickness) are easy to purchase, while radially magnetized seem impossible to find. Maybe they are special made.
Are there other advantages in one design over the other?
Feb 3, 2007. 10:16 PMPunkguyta says:
Would it be possible to wind the core with a finer gauge of wire to add a bit more strength/accuracy?
Feb 4, 2007. 4:16 AMPunkguyta says:
Ok, makes sense. So have had any succesful experiments with this with either salt or water?
Sep 13, 2006. 3:31 PMstonehenge360 says:
im probabily going to sound like an idiot, but what exactly does this do?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:corwin
182x62x24cm - 308 kg/m^3
