Step 2Prepare The Base
First you need to drill a hole in the back of each box for the support wire to go through. Also cut holes for the power switch, power input, set height button and LED indicator. You also need to cut most of the bottom of the ring box out, just leaving a lip on the bottom.
Support the ring box above the base box by using some heavy gauge steel wire, bent to the shape and height you want. Next, wrap the electrical wire around the steel wire, then cover all of it with the vinyl tubing (optional) as seen below.
Next, bend the bottom end of the support in a zig zag pattern and use hot glue to secure it to the inside of the bottom case (see second picture below). I secured the ring box to the top of the support wire by using a magnet, but it could also stuck on by hot glue.
comment
Add Comment
Add Comment
![EMP HDD Launcher, [HD Video]](http://img.instructables.com/files/deriv/FUM/QO3R/GQBCI72I/FUMQO3RGQBCI72I.SQUARE.jpg)
