Step 4Build the Electronics
It is very important to plan where all of the parts go, so all of the electronics will fit in the box the first time, If not it could be very frustrating and cause much grief.
It is also important to note that the NPN power transistor(s) will heat up, to overcome this I mounted them to contact the aluminum base of my project box, This way it acts as a heat sink, preventing a spectacular fire. You will also need to come up with something similar to remove most of the heat from the box.
Once the electronics are built, there is a section of code in the program to uncomment and and then load onto the chip to test the orientation of the coils. It pulses the coils off, pulling up, and pushing down, also indicated by the LED. If you hold a magnet under the electromagnets and it doesn't follow the pattern, reverse the wires.
Floating_Magnets.hex24 KB| « Previous Step | Download PDFView All Steps | Next Step » |
![EMP HDD Launcher, [HD Video]](http://img.instructables.com/files/deriv/FUM/QO3R/GQBCI72I/FUMQO3RGQBCI72I.SQUARE.jpg)
thanks
PS: I love it, I saw one that wasn't for sale at a shop, so ever since then, I wanted to buy one, but making one would be even better!
