3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electromagnetic Floater
Step 6Start Floating
Start Floating
All that is left to do is start floating the objects.
This is done by holding the object under the magnets and slowly bringing it up. When It nears the point where it wants to float up, push the button. This will set the level to float at to the current height.
Next, hold it just below where you set the hold height, so the LED lights up. Hold it there until it simply floats out of your hand. This happens because the microcontroller slowly adjusts the hold height up, to where the electromagnets have enough power to control the object.
You may also notice some buzzing coming from the electromagnets. This can be easily fixed by inserting some padding around the electromagnets.
If you do make this I would love to see some photos. It would also be great to hear any comments you have.
30 comments
May 12, 2011. 10:55 AMbkrishnan1 says:
its very nice can you send which electromagnetic coil used
Dec 23, 2008. 10:59 PMpianoman2011 says:
i was thinking... since the power jack is a 1/8" audio jack, if you used a jack converter and plugged the device into a cd player/iPod, would the change in the electrical signal when you play a song sort of move the magnet with the music? would an amplification system be needed to strengthen the signals to sufficiently power the device, if this was all possible?
Apr 6, 2011. 3:44 AMscraciun says:
hello i really need your help:) you didn t say anything about the program
Feb 10, 2009. 4:21 PMpianoman2011 says:
but if you amplified the audio feed current, or just added to it so that the slight changes in voltage would make the magent float, it still wouldnt work?
Feb 11, 2009. 6:35 AMpianoman2011 says:
that would be neat. but i gues i am only dreaming lol
Mar 13, 2009. 6:45 AMAercimete says:
you might be able to put a secondary electromagnet in(much weaker) so that the primary suspends it and the secondary just kinda wiggles it lol
Dec 11, 2010. 5:05 AMcoleyy says:
it might be easier to do that to a smaller magnet like Aercimete said and put that next to the object
Mar 15, 2009. 6:47 PMpianoman2011 says:
lol nice idea. but now that i really think about it, i don't think having it wiggle to music would be that fascinating... still worth doing though.
Jun 5, 2010. 9:58 PMDehLeprechaun says:
wonder if you could beef it up and make floating furniture
Oct 20, 2010. 6:06 PMpyrotech45 says:
they actually do have floating beds but they are expensive
Oct 20, 2010. 6:13 PMDehLeprechaun says:
send me a link i'd like 2 luk at it
Oct 24, 2010. 7:45 PMpyrotech45 says:
http://zedomax.com/blog/2007/02/18/magnetic-floating-bed/
Dec 5, 2010. 8:54 AMChimex14 says:
DANG!
Nov 17, 2010. 3:02 PMgtyrfdrty says:
holy crap thats cool
Jun 22, 2010. 8:59 AMnatman3400 says:
And then sit in it. That would be awesome. Or a floating bed-sized ferofulid ball that you could sleep on.
Aug 22, 2011. 12:39 AMmonkeys98 says:
it would suck if it stopped working when you were sleeping SMACK!
Jul 1, 2010. 6:01 PMDehLeprechaun says:
i think the ferofluid would be a bad idea the second you lay on it you would fall through and be soaked in it. not to mention you might drown.
Jul 2, 2010. 10:01 AMnatman3400 says:
Fill a waterbed with it?
Jul 3, 2010. 10:23 PMDehLeprechaun says:
that would probably work better but theres no telling what shape it would be or if it would float at all
Oct 31, 2010. 1:56 PMdombeef says:
It would spike you though
Nov 6, 2010. 6:51 PMnatman3400 says:
make it weak then
Nov 7, 2010. 5:51 AMdombeef says:
It would just be a regular water bed then
Dec 30, 2010. 9:38 PMkillerdynamo says:
no, it'd be a really badass waterbed
Dec 30, 2010. 11:02 PMnatman3400 says:
It be a really badass floating water bed. PWNT fools.
Dec 31, 2010. 5:45 PMdombeef says:
It would be a watery blob,if it was in a skin of some kind it would be a cool bean bag chair
Dec 31, 2010. 6:41 PMkillerdynamo says:
and if your pants were magnetic... now we're getting somewhere! haha
Jan 2, 2011. 1:31 PMdombeef says:
Owww, ultra wedgy
Dec 30, 2009. 9:34 PMMrmHend says:
Will Any Object Float?
Jan 5, 2010. 3:06 PMmelyguitargirl says:
no..i think it has to be magnetic..i suppose that the yarn ball has some kind of magnet inside of it..
Sep 1, 2010. 7:37 AMmwagner63 says:
its not a yarn ball its a die
Jul 14, 2010. 5:11 PMDehLeprechaun says:
i was wondering if you could put a seperate coile to power a lap floater or if that would interupt the field holding it up
Jul 8, 2010. 3:20 PMDehLeprechaun says:
i wonder if you could intigrate this into a vehicle and like have a second one in the back that pulsed to propel the car forward then you could sink magnets into the streets
Sep 5, 2008. 4:42 AMWannabe117 says:
Hey was wondering is their anyway you could create a small "spin" in the magnetic field to make your object spin slowly all day would look great, also this is my first project and would like to know what substitue parts i could use as i cant find the entire list in my area
Jul 5, 2010. 9:10 AMinfactiam says:
Actually, this could be accomplished fairly easily, without what most would consider a motor, but it would require making another device almost identical to the original floater. You could hide a small vertical conducting loop in your object and add a second solenoid pointing sideways at the object. This magnetic field induces a current in the loop by Faraday's Law when its plane is not parallel to the magnetic field (which it never perfectly is), and there's a torque on the resulting current loop in the preexisting magnetic field. The only caveat is that like any electric motor, the torque will switch directions every time the plane of the loop crosses the field and, if left on, drive the loop to that parallel position. So you have to pulse the magnetic field to be on only for half of the time, for which you would need another sensor and essentially be building a second floater. Electric motors accomplish this switching either with a moving wire brush contact or with electronic timing. I would suggest an optical sensor and a marking on your object. To get really sneaky, you could make it an infrared sensor and get some infrared reflective paint so no one can tell the difference.
Jul 6, 2010. 10:45 AMinfactiam says:
btw I probably should have been more clear that in this case you also need an oscillator for the voltage through the electromagnet (the induced current will respond to CHANGES in the magnetic field!).
Nov 19, 2009. 9:05 AMnecropolian says:
a microwave oven motor is perfect for this. slowly spinning...
Sep 21, 2009. 9:59 PMkillerezv says:
, make the base bigger, I would add a motor to it, and have it spin, though add the rare earth magnets on the motor and have it balanced will be tricky
May 16, 2009. 11:29 AMxtremd says:
You could spin a magnet and the floating magnet would also spin.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
98
Author:J_Hodgie
Currently doing masters in Mechatronics Engineering, but still create in my spare time
