3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electromagnetic Pen
Electromagnetic Pen
This pen-like object turns into a magnet, an electromagnet. How it all works: When a DC power supply goes through a coil of magnet wire, some of the energy is stored around the coil in a field. Introducing my first instructable: Electromagnetic Pen!
(Doesn't actually write. Just looks close to a pen) You don't have to use battery holder, you can use a bench-top power supply!
http://www.youtube.com/watch?v=AERfL4Q5JJo   < around ten second video!
Step 1
Tools needed:
Soldering gun
Solder
Helping Hands (optional)
Wire strippers
Wire cutters
If I use some tools not listed. I will post.
Materials:
Magnet wire (a lot)
Electrical tape
Steel rod (Mine is a 6 inch steel rod) Better if you use iron.
Heat shrink (just a little bit shorter than steel rod. The rod should slide through the heat shrink easily)
Small push button (momentary- Completes circuit when pressed)
Battery holder (doesn't matter size. Just don't use a 9v or it will get too hot. Or use a desktop power supply)
7 comments
Jan 23, 2012. 3:28 AMRSV26 says:
u should rename it to E.M.P eletrical magnat pen!!!!
Nov 19, 2011. 2:30 AMKryptonite says:
I'd love to see examples of general uses for this: wiping cards, hard drives, causing havoc... the usual!
Nov 24, 2011. 3:33 AMKryptonite says:
Oh, but of course!
Nov 21, 2011. 9:54 AMkillbox says:
wonder if you up the gauses and perhaps make a point at one end (perhaps use a screw or nail in the end) if one could draw patterns on steel, and then get metal filings to stick.
Nov 21, 2011. 7:53 AMmrmerino says:
The next logical step is to create a functioning pen with an electromagnet concealed inside....
I can almost smell the mayhem.
Nov 20, 2011. 9:21 PMMark Rehorst says:
I'm not so sure I get the point of making an electromagnetic pen, but I really like the white board as photo background technique! It let's you add notes and arrows, and as much text as you can fit in the photo. Brilliant! I'm going to use that technique on an 'ible one of these days.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:alpe_97
I love instructables
