3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electromechanical Transducer Out of a Polystyrene Conical Section!
"A what?" you ask. An "electromechanical transducer" refers to the type of speakers we are most familiar with; a permanent magnet and an electromagnet wildly vibrating to produce sound. And by "polystyrene conical section" I mean plastic cup.
Whatever this is, it is not an Instructable on how to callously rip apart your roommate's computer speaker and glue the driver into some other object. I show how to build the actual transducer unit (commonly called a speaker driver) with a few simple objects. The speaker is super easy, extremely impressive, and so cool that it even makes Kenny G. sound good.
If you are abhorred by reading, feel free to cut to the meat of the how to on step 3. But the theory I present in the first few pages may help you build a better speaker, and... (dramatic pause)... may even make you smarter (Egad!)
There are a couple risks (other than learning) so please read the Safety Page.
Step 1Theory: What is Sound
The first concept to wrap your rubbery little mind around is the idea of sound. Sound isn't an object. Your boom box isn't firing little particles of magic sound dust to tickle your ears with M.C. Hammer. Instead, sound is the transfer of energy.
A source (such as the speaker on you boom box) is receiving electrical energy and converting it into mechanical energy. If you'll kindly place your fingers against your throat and scream the phrase, "someone's already made a movie about a giant singing plant," you'll feel that mechanical energy in the form of vibrations. You'll also have noticed those vibrations when you stand really close to a drum set or those cheap speakers your ex-girlfriend blasts Smash Mouth on.
That mechanical vibration acts like a piston pushing particles forward when it moves outward and pulling particles backwards when it pulls in. Like I said, sound isn't an object; it is a transfer of energy. Those particles are not hurling towards your ears. The first particle touches the next particle and moves it a bit. That particle moves the next particle a little bit, and so on until that movement, that energy, reaches your ear. How fast those particles transfer energy (the speed of sound) is determined by what type of particle it is. In air, sound moves at 343 meters per second. In your secret underwater sea lab it moves at 1533 meters per second (I won't tell anyone).
I know you implicitly understand this, because you're super smart, but small sources move a small number of particles and big sources move a big number of particles. If the mechanical vibration is small (if the piston only moves a short distance), it doesn't transfer much energy to the particles so the sound is small. If your speaker is really athump'n (the piston moves a large distance) it is transferring large amounts of energy and it produces large sound.
One last note on the concept of sound, we say sound is a wave. But it isn't one of those up and down waves like a jump rope or those sine graphs your algebra teacher makes you draw. It is a back and forth sort of wave featuring a series of particles pressed really close together and particles spread far apart. If you stretch a good slinky out on the ground and give it a push (a push not a wiggle! a push I said!) you'll see another example of this type of wave.
70 comments
1-40 of 70next »
Sep 16, 2011. 9:22 AMspark master says:
if the wire is short length place on a flat work table place a plank over it and roll it back and forth(like a rolling pin motion). You will preserve the insulation and it gets it very straight. Use this for making darts on job site. worked well.
Nov 25, 2010. 6:24 AMc0rtx says:
i wonder if anyone knew that you can use this same principle in reverse to generate electricity, its called thermo acoustic power....heat directly to electricity, the only moving part is the plastic membrane at the end of the cone(heat expands gas creating a pressure wave flexing the membrane with a coil, a pressure wave in gas is also known as sound, hence thermo acoustic) russians used the technology to power radar stations off kerosene room heaters durring the cold war
May 13, 2009. 4:09 AMMandela says:
Nice explanation and pictures ! (maybe you dont have to write the explanation, just show the images!) :P Confused still with the sound source.. Would you show the images from the sound source? (like from ipod) Requesting electric guitar amplifier :P
May 13, 2009. 3:00 AMpyroten says:
great i'ble just thought i'd point it out in step 2 paragraph 2 line 6 last word u spelt "bass" like "base" but gud wrk (Y)
Dec 17, 2008. 2:41 PMPKTraceur says:
What is magnet wire? Im attempting a Faraday AC generator. but cant find any 'Magnet wire"
May 13, 2009. 2:58 AMpyroten says:
magnet wire is i believe just a strand of copper wire in different gauges that is coated in a thin sometimes thick protective clear layer which does not interfere with a magnetic field. sometimes it comes under enameled wire i think
Apr 26, 2009. 4:36 PMProphesyOfWolf says:
Trippy! I made one of these in like 5 minutes. As previously said, the sound was weak. But it was definitely there! Good instructable =P
Jan 18, 2009. 5:11 AMcyberpageman says:
There is a design problem with this plastic cup speaker. The magnetic field from the coil has to move the heavy mass of the permanent magnets to produce sound. The magnets shouldn't be touching the plastic cup. Check out http://www.instructables.com/id/Homemade-speaker/ which shows how that can be done.
Apr 27, 2008. 8:08 PMsteadmanjon says:
This actually worked. I used an empty peanut can and some alligator clips. The sound was very weak, but I could hear it.
Nov 28, 2008. 5:24 PMchriskarr says:
Well... ...the whole superglue in a plastic cup thing worries me. If the cup is made of the wrong kind of plastic, the super glue will dissolve it. Please test the cup first!
Nov 28, 2008. 5:21 PMchriskarr says:
Not a SHARP edge, as in one that could be used to cut something but, instead, something soft, like wood, with a bit of an edge to it (like the edge of your mom's coffee table!).
Aug 15, 2008. 1:02 AMAlexizupinhea says:
I just wanted to say that I have found this instructable very informative and the comments and chats below have truely opened my mind to all sorts of thinking. I know it sounds corny... but I hope I can design and create a very effective... efficient... quality... long lasting speaker for under $2-$5
Apr 3, 2008. 9:09 AMgomjabar says:
As with many instructables the terms "a few household items" or your "simple objects" leave a lot to the imagination. 5/16 round 1/8" thick disk neodymium magnets and 40" 16 gauge enameled wire are not exactly "simple objects". That is to say things I just have laying around. How about a small portable particle accelerator? Maybe all I have is a 5/16" round 1/8" thick disk sumarium or cobalt magnet. Don't say "simple"!
Aug 4, 2008. 6:00 PMrocketman221 says:
i have high power neodymium magnets and lots of magnet wire laying around. doesnt everyone
Aug 6, 2008. 10:50 PMthermoelectric says:
I do
Aug 6, 2008. 10:51 PMthermoelectric says:
HDD magnets and magnet wire out of crt monitors
May 22, 2008. 4:29 PMbeaulingpin says:
Who doesn't have magnets and wire? Hell, you could even cut up one of those flexible magnets (like the "support our troops" ribbon magnets people put on their cars) into little disks and stack them. As for wire, this could be any thin wire. Granted, you get the best result from wire without plastic insulation (as they reduce the number of coils you can make in the closest area to the magnets), but any wire will create a flux that acts in the magnetic field. So hey, don't complain. And anyway, it's really easy to make a particle accelerator too. Get a longitudinal spring and a ball that has a diameter greater than the diameter of the spring, and use the spring to accelerate that particle. It's not as nice as the accelerator I work at, but it fits the definition. but anyway, without imagination, even following instructions are too hard for some people
Jun 14, 2009. 1:34 PMaplauche says:
LOLOLOLOLOLOL this just made me laugh anyways good instructable although the speaker works better if the solid state magnet is not directly linked to the vibrating part of the plastic cup.
Aug 12, 2007. 5:50 PMkillerjackalope says:
theres transverse and lateral waves i think these are lateral that go back and forth but i can't remember right know
Sep 22, 2007. 4:25 AMKiteman says:
Transverse waves go side-to-side (the traditional sine wave). Sound waves are longitudinal - they vibrate back and forth in in the direction the wave is travelling.
Check these animations to see the difference.
Sep 22, 2007. 12:42 PMkillerjackalope says:
thats alright then I just couldn't remember sorry my physics teacher called them lateral as she was a twit, seriously during the energy transfer experiments I tricked her into letting me smoke in class
Aug 4, 2008. 2:46 PMthermoelectric says:
(removed by author or community request)
Aug 4, 2008. 4:15 PMkillerjackalope says:
Don't even start. I'm really really tired of this one. Go annoy someone else, please.
Aug 6, 2008. 1:53 PMthermoelectric says:
I'm sorry
Aug 6, 2008. 2:41 PMkillerjackalope says:
Thank you for stopping...
Aug 6, 2008. 10:42 PMthermoelectric says:
My pleasure
Mar 28, 2008. 10:17 PMTheMadScientist says:
could this quite possibly be made out of an expanded polystyrene conical section as well? :D WOOT, FOAM!
Jun 22, 2008. 9:41 AMDerin says:
eh...directional (read:padding) but it would work wonders
Jun 13, 2008. 12:25 PMbliz23 says:
Would a resistor help with cutting down on the current?
Mar 28, 2008. 10:12 PMTheMadScientist says:
Feb 3, 2008. 3:09 PMWareagle says:
wow..... this is pretty cool.
Oct 22, 2007. 3:25 PMKiteman says:
Regarding step 7 - does it matter if the coil is attached to the outside of the cup? I'd like to make these with my science club, and some of them have distinct manual dexterity problems.
Oct 23, 2007. 5:01 AMKiteman says:
Thank you. Normally I would tell them that myself, but I have a policy of opening Science Club to all interested children (the only qualification is good behaviour), and this year I seem to mainly have kids with plenty of enthusiasm but little actual ability (we made simple wind turbines recently, just paper and glue, and only about half even turned...)
If these work, I have a half-warmed idea to make a short Ruben's Tube with the speakers, but I'm still persuading my Head of Department that that would be safe...
Dec 12, 2007. 3:24 PMBongmaster says:
Now thats a kool tube :)
Nov 29, 2007. 2:14 PMfade400 says:
excellent. I'm going to recreate this as soon as I get some magnets. I was wondering however, did you achieve the best sounding speaker from the plastic cup or were you able to find a better material ? By better sounding, I mean better sounding in terms of music not random sounds. Thanks
1-40 of 70next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:Bookburn
