I had to do something different, though, for the bass pedal.
This design is what i came up with.
I'm going to rely on pictures more and text less than in my other instructable.
Remove these ads by
Signing UpStep 1Materials + Tools
1x - 3/4" wood, 4x12"
1x - 3/4" wood, 4x3.5"
1x - wood, 4x4x3"
2x - 3" metal corner brackets
2x - 1/4" foam, 3x4"
1x - sheet metal, 3x4"
1x - sheet metal, about 3x2"
1x - Peizo sensor (35mm)
1x - RCA style phono jack
2x - legs/"spurs" from acoustic bass drum
Heavy cloth and vinyl for covering.
Screws - long and short
Tools:
Drill + bits (screw drive, 1/2 inch, 1/4 inch, small size for pilot holes for screws.
Saw (I just used a hand saw, but anything will work
Chisel
Screwdrivers
Heavy duty stapler and staples (at least 1/4")
Hot-Glue gun with glue
I made some piezo drum triggers (for acoustic drums) that attach to the drum heads and used the arduino to trigger relays that turn on lights. Whenever our drummer hits a certain drum, the corresponding light turns on for a predetermined length of time. Thats the plan right now but so far i only have the arduino programmed for the bass drum.
I have to say when our drummer uses his double kickers with the lights it looks pretty good in the dark!
The arduino website:
www.arduino.cc
you should be able to find almost everything on that website and/or the forum.
