3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electronic Canary
Electronic Canary
This instructable will cover all the basics involved in building an electronic canary. This is a excellent weekend project. This circuit recreates accurately the sound produced by a canary.
All components for this project should cost under $10
Basic soldering and electronic skills required
For a preview for the sound it makes. The file is below the picture.
Step 1Preparation
Preparation
Equipment Required
Soldering Iron
Pliers
Work Station
Parts Required
Resistors
1 x 47k Ohm
1 x 4.7k Ohm
Transistors
1 x BC109 or BC337
Transformers
1 x 1K:8Ohm Audio Transformer
Capacitors
1 x 22nF Ceramic
1 x 10nF Ceramic
2 x 100uF Electrolytic
Other
1 x 9v Battery and Clip
1 x Plastic Board
1.5m of Copper Foil Tape
1 x C2222 8Ohm Speaker
1 x Momentary Push Switch
8 comments
Dec 18, 2010. 10:28 PMojacob says:
Hi I'm am currently trying to build this circuit with a pcb that I designed but I can't find an audio transformer nowhere, I found a couple of old radios and nothing radioshack doesn't have them either, wherebcan I possibly find it? Thanks!!!
Jul 17, 2008. 9:25 PMHands Without Shadows says:
A 47000 ohm resistor is yellow, violet, orange, tolerance A 4700 ohm resistor is yellow, violet, red, tolerance
Feb 8, 2009. 6:37 PMcd41 says:
is there a site with all of that stuff on it(the resistor codes) and all? i have alot of them on a piece of marked cardboard but i don't want to take them off cause i don't want to mix it up
Jul 16, 2009. 9:38 AMcyberpageman says:
Try http://wiki.xtronics.com/index.php/Resistor_Codes or search for "resistor color codes."
Jul 17, 2008. 9:51 PMalex-sharetskiy says:
Get a breadboard!
Feb 8, 2009. 6:35 PMcd41 says:
they aren't necessary for everything plus this way you can put it w/e you want not just where the board will fit
Feb 8, 2009. 6:37 PMalex-sharetskiy says:
if i really wanted to, i could make this into a a cube with the area of 1in3
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:fatboyslim
