This project describes how to build a simple, safe, and reliable electronic detonator. All the parts should total under 25$, and all but one of the parts can be bought at radio shack. This detonator includes numerous safety features such as a detachable power supply, an ARM switch, and an indicator light.
Remove these ads by
Signing UpStep 1Parts list
Parts:
1. Project box (As close to 3x2x1.5 as you can get, remember you need enough room to hold the components but you want a good fit for your hand)
2. A momentary push switch (Model: 275-609)
3. Toggle Switch with On/Off Label Plate (Model:275-602)
4. 5mm Green LED (Model: 276-022)
5. 1/8" Mono Panel-Mount Audio Jack (Model: 274-251) its a 3 pack see but you only need 1.
6. 1/4" mono Panel-Mount Audio Jack (Catalog #: 274-252)
7. 1/8 Mono Phone Plug (Model: 274-286)
8. 2-Conductor Standard Phone Plug (Model: 274-1544) I think thats the one I got, Its got the picture on the website that most looks like mine, however, I'm sure any 1/4" mono (even stereo but then you'd have to pay closer attention to your wiring) plug would work.
9. Soldering Iron and solder
10. 2-Conductor Intercom Wire (Model: 278-857) Im pretty sure thats the wire I bought.
11. Heavy-Duty 9V Snap Connectors (Model: 270-324) Like the other packages it has more then you need
12. 8 AA Battery Holder (Model: 270-407)
13. 8-Pack AA Enercell® Alkaline Batteries (Model: 23-874)
14. Slim Line 2" Alligator Clips (Model: 270-346)
15. Drill with assorted bits
16. Spare hookup wire (You can cut off some of the intercom wire if you need to)
17. Nichrome wire (Can either be bought on e-bay or Unitednuclear.com) make sure you don't get the wire too thick I use unitednuclear.com, but I don't know what gauge it is.
18. I'm assuming you have tools like screwdrivers and wire cutters.
Don't try and use hot glue either. The solder actually joins the two bits of wire, instead of just "holding them together" like tape or hot glue.
Otherwise... awesome! Sorry for being negative in the beginning, but I actually think this instructable is really cool. The arm switch and detachable power supply are clever... now just to make it remote controlled ;)
I paid almost 50 for everything.
I'm good with pyrotechnics but not so great with electronics (except lasers),
doesn't electricity take the easiest path so would just go through the led and not touch the toggle switch?
Also could the led handle 8 batteries without a resistor?
thanks
http://en.wikipedia.org/wiki/Nichrome
http://en.wikipedia.org/wiki/Vacancy
http://en.wikipedia.org/wiki/Lattice_vibration
http://en.wikipedia.org/wiki/Electron_mobility
mine is made from a mint tin.
coz i cant get nichrome
Cuprothal gets to 400 celcius
although, i'd always go with the cell phone detonator...wireless! :D
...and it used satellites, so you can be however far away.
Great box, BTW!
http://www.instructables.com/id/Super-Cool-Electronic-Detonator/
