Introduction: Electronic Drum With AB-Shutter3
Picture of Electronic Drum With AB-Shutter3
Electronic drum with AB-Shutter3
AB-Shutter3 is a camera shutter button for smartphones.
AB-Shutter3 connects to the equipment with bluetooth.
AB-Shutter3 is sold at Daiso in Japan (as of 2017).
I made an electronic drum with AB-Shutter3.
When you press the AB-Shutter3 button, you will hear a sound from the MIDI connected software synthesizer.
First of all, please see the video.
AB-Shutter3 is connected to Raspberry Pi as a Bluetooth keyboard.
Raspberry Pi uses Node-RED.
Node-RED converts button event of AB-Shutter3 to MIDI signal.
Send the MIDI signal to the software synthesizer. The software synthesizer gives a sound to the speaker.
Step 1: Setting Up Raspberry Pi
Picture of Setting Up Raspberry Pi
1. Pairing AB-Shutter3 and Raspberry Pi
2. Install the software synthesizer on Raspberry Pi
Please use your favorite software synthesizer. I am using Qsynth in the video.
Step 2: Setting Up Node-RED
Picture of Setting Up Node-RED
1. Install the AB-Shutter3 button node on Node-RED on Raspberry Pi
For details, please see the following. https://github.com/arrowmeiwaracing/AB-Shutter3V2
2. Install the MIDI library
https://flows.nodered.org/node/node-red-contrib-midi
3. Write sample flow to Node-RED
  • Open "dram_node_example.json" with an editor.
  • Copy it to the clipboard.
  • Copy the flow to Node-RED (Node-RED Menu => Read => Clipboard).
Step 3: Setting Up Synthesizer
Picture of Setting Up Synthesizer
1. Set the drum sound of the GS sound source to Channel 1
2. Open the MIDI OUT node of Node-RED and specify the MIDI port of the synthesizer
Note: The name varies depending on the software.
Step 4: Performance
Picture of Performance
Let's play now. Respond to the following operations.
  • Large button click
  • Large button long press
  • Small button click
  • Small button long press
Step 5: To the End
Picture of To the End
Let's change it to your favorite sound.
Happy instructables.
About This Instructable
554views
5favorites
License:
Bio: I like 100 yen shop. I like home improvement center. I like IKEA. I like motor sports.
More by 明和自動車:Maze Game to Control With SmartphoneElectronic Drum With AB-Shutter3Caster Mounting Example of Water Pipe Furniture
Add instructable to:
