loading
Step 4: Acoustic vs electronic cymbals
This has been another issue for debate.
Many purists will refuse to play anything other than acoustic cymbals.
I can't blame them having played acoustic drums for over 20 years myself.
I'ts hard to replicate the nuances of the real thing with rubber and electronics.
I bet that argument is pretty similar to the one they must have had when only acoustic guitars existed and somebody "dared" to mention an "electric" guitar. Many years have passed and now both types of guitars coexist peacefully and in total harmony. (no pun intended). Many years have also passed since the first electronic sets and cymbals were created and today's market is full of excellent choices, that's is not to say that DIY'ers are left out. I will soon post a tutorial on making your own electronic cymbals with different variations and detailed explanations of course.
The pictures below show two different types of electronic cymbals
The Alesis cymbals are brass (real cymbals) covered with a coating that mutes their acoustic sound but retains the look and feel.
The Pintech are rubber (they have different models at different prices)
quieter than the brass cymbals but if you are going for looks then brass is the way to go.
There are many ways to convert an acoustic cymbal into an electronic one, YouTube is full of DIY'er examples on that subject.
<p>Hello, can you upload a draw of a 3 zone ride please and how to build it, because i search everywere and i dont know how to do it. Thanks for the help!!</p>
<p>I am not sure on how to do that but in the Toontrack website there are quite a lot of tutorials on how to do that, you need to sign up to see them, but you can check out this: </p><p><a href="http://www.google.com/imgres?imgurl=http%3A%2F%2Fi78.photobucket.com%2Falbums%2Fj116%2Fdmkpo%2F3-zone%252520ride%2FMYTHREEZONE.jpg&imgrefurl=http%3A%2F%2Fwww.vdrums.com%2Fforum%2Fforum%2Fadvanced%2Fdiy%2F40865-my-three-zone-ride-w-choke-stealth&h=487&w=540&tbnid=NA-7BILqbWthiM%3A&zoom=1&docid=nNaL8k3AGKJDRM&ei=lsivU7_jFoqFogThkoHAAw&tbm=isch&ved=0CB8QMygBMAE&iact=rc&uact=3&dur=1200&page=1&start=0&ndsp=24" rel="nofollow">http://www.google.com/imgres?imgurl=http%3A%2F%2Fi...</a></p><p>or this: </p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/W6HjxoNGhEU" width="500"></iframe></p>
<br>it is realy wonderful i wish to have it made by me <br>but <br>sir my question is <br>how to use STEAVEN STEL DRUM SOFTWQRE &amp; ASIO WITH WITH HOME MADE ELECTRONIC PAD . PLEASE HELP ME SIR <br> <br> <br> MAHESH a drummer <br> <br> <br>
First things first: <br> <br>You mentioned that you have a home made pad... <br>how are you connecting it to the computer? <br> <br>If that is part of your question (how to connect a pad to the computer), then I can suggest a couple of ways, some better than others though as more appropriate choices can be made with the right equipment and not so great choices with lack of equipment. <br> <br>Way number one: (single pad with a 1/8 or 1/4 female connector + no external sound card: <br>Depending on the connector (1/8 or 1/4), find a cable that goes from the pad to the mic input on your computer. This will work but your sound quality will suffer as Windows is not great for connected instruments due to the generic nature of the on board sound card. In other words, it is not designed to be very efficient for inputs since people who record instruments and such, will generally have a dedicated sound card with the right inputs. That said, this method will work but it isn't ideal. Once that connection is made you can open your DAW (your music production program) open Steven Slate Drum inside it, and ensure that you can set your mic input as a midi input on the program's MIDI dialog box. Again this will work but not great due to latency. <br> <br>Option number 2 <br>Home made pad + Drum module+ Sound Card: <br>Probably the easiest way. Just connect the output of the drum module to the sound card and ensure the sound card is selected as the MIDI input on your DAW. Some drum modules even have a USB out which is used to connect straight to the computer to send MIDI data making it even easier to connect your drums to the computer. You still need a sound card to eliminate latency. <br>most sound cards will be compatible with ASIO drivers or may have their proprietary version of ASIO. the drivers are optimized to improve performance and eliminate latency and other issues. <br>Some other modules only have audio out and MIDI out but not USB that is still ok as long as you have either a MIDI to USB adaptor , or your sound card has a MIDI input so you can connect from the MIDI out of your drum module to your sound card's MIDI in. there are plenty of MIDI to USB adaptors out there for very cheap but if you get one check customer reviews before spending your $$ <br>there is also the Alesis I/O which is designed specifically to connect drum pads and to be connected to a computer, it is not new but it also isn't expensive which is why it is still around. if you have any more questions let me know and I will try to give you a decent answer.
I will make a tutorial on how to use drum sofware in the very near future, I had typed a long answer but it dissapeared so now i am left with this lame answer,sorry, but stay tuned and you will get a better answer, even with pictures.
outstanding and well done,...thank you
Thank you for taking the time to read and comment, Sorry for not being here more often , I promise to make more tutorials and answer questions as I get them.
that an ok to use?
??? I did not understand your question.<br><br>please try to be more specific<br> <br>or post it in Spanish if you speak it.<br><br>(Those are the two languages I speak)
it meaning to say it is good to use because it is my favorite <br> music instrument!!!!!
About This Instructable
45,401views
33favorites
License:
Bio: I am a musician, but not professional, I have been in many bands over 18 years and have different experiences from them. Being in the ... More »
More by doggyd69b:How to Convert any acoustic drum into an electric drum step by step guide Electronic Bass Drum Concept Electronic Drums Lingo
Add instructable to:
