3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electronic Fly Swatter Power Mod
  • last photo ←
This is how to modify the electronic fly swatter increasing the power level output from 800 volts at around 1800 volts.
This is a duel button unit where both buttons need to be depressed to activate it. I have used one of the buttons to allow it to function in normal mode and bypassed the need to hold both to operate it.
When using this in high power mod mode or 'Evil' mode as I like to call it! be aware that the grid will hold a charge for up to 5 minutes. To discharge it hold the modded button and then press the other button for 3 or more seconds, let go of the non-modded button before the modded button to be certain it has discharged.
Touching the electronic grid before modification is unpleasant to say the least, however touching it in its modified mode just plain hurts so avoid it unless your some sort of pain freak!
Step 1Bypass Power Button
Bypass Power Button
First remove the PCB tracks for the power button leaving the switch free and bypass it with a bit of wire as highlighted in yellow in the picture.
3 comments
Aug 5, 2011. 1:15 PMdisturbia says:
Not being offensive, but he won't read this reply seeing as you didn't press the "reply" button. :)
Jul 12, 2011. 4:00 AMcurious youth says:
using this to make a taser ? i think yes :)) thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:sparkyuiop(Dorchester Computer Repairs)
