3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electronic Stethoscope
An electronic stethoscope is an easy and fun listening device to make. It only requires some basic knowledge of electronics, and can be built with some basic easy to find parts. I have been having a great time using it to crack saf... I mean listen to my heartbeat. Yes! I have been having a great time listening to my inner workings.
Step 1Go get stuff
Go get stuff
You will need:
- 1-1/2" flat round cabinet knob
- LM386 Low Voltage Audio Power Amplifier (Model: LM386 | Catalog #: 276-1731)
- MPF102 Transistors (Model: MPF102 FET | Catalog #: 276-2062)
- 1K Ohm 1/4-Watt Carbon Film Resistor (Model: 271-1321 | Catalog #: 271-1321)
- 1M Ohm 1/4-Watt Carbon Film Resistor (Model: 271-1356 | Catalog #: 271-1356)
- 10 ohm 1/4W 5% Carbon Film Resistor (Model: 271-1301 | Catalog #: 271-1301)
- 4.7K Ohm 1/4-Watt Carbon Film Resistor (Model: 271-1330 | Catalog #: 271-1330)
- (x2) 0.047µF 50V 10% PC-Mount Capacitor (Model: 272-1068 | Catalog #: 272-1068)
- 220µF 35V 20% Radial-lead Electrolytic Capacitor (Model: 272-1029 | Catalog #: 272-1029)
- 100µF 35V 20% Radial-lead Electrolytic Capacitor (Model: 272-1028 | Catalog #: 272-1028)
- 0.1µF 50V Hi-Q Ceramic Disc Capacitor (Model: 272-135 | Catalog #: 272-135)
- Project Enclosure (3x2x1") (Model: 270-1801 | Catalog #: 270-1801)
- Multipurpose PC Board with 417 Holes (Model: 276-150 | Catalog #: 276-150)
- JVC® Gumy Earbuds (Model: HAF150B | Catalog #: 55042619)
- 10K-Ohm Linear-Taper Potentiometer (Model: 271-1715 | Catalog #: 271-1715)
- Hexagonal Control Knob (Model: 274-407 | Catalog #: 274-407)
- 1/8" Mono Panel-Mount Audio Jack (Model: 274-251 | Catalog #: 274-251)
- 6-Ft. Mono 1/8" Plug to Mono 1/8" Jack with Shielded Cable (Model: 42-2472 | Catalog #: 42-2472)
- Fully Insulated 9V Battery Snap Connectors (Model: 270-325 | Catalog #: 270-325)
- Enercell® Alkaline 9 Volt Battery (Model: 23-853 | Catalog #: 23-853)
- 90dB Piezo Pulse (Model: 273-066 | Catalog #: 273-066)
7 comments
Mar 29, 2012. 7:12 PMrenanmarc says:
Where do I solder the Mono Panel-Mount Audio Jack?
Dec 27, 2011. 7:16 PMacmefixer says:
If this is going to be used for very low frequencies (that's the whole idea of a stethoscope), then the .047 uF between the 4.7k and 10k volume control should be replaced with a much larger capacitor, 1 uF or more. The positive end should go towards the 4.7k.
And since you already have a volume control, why not just replace the 1k between pins 1 and 8 with the 10uF capacitor recommended in the datasheet. BTW, even if you use the resistor, the datasheet still recommends using the 10uF capacitor in series with it.
Sep 19, 2011. 4:34 AMdas007 says:
is there any equivalent of lm386. I do have lm380 can i use it.....?
Oct 27, 2011. 3:41 PMblinkyblinky says:
I'm actually building this with LM358. It should work but make sure you use the correct pinouts.
Jul 19, 2011. 9:56 PMmat1978 says:
I'm so building this one :)
Jul 11, 2011. 5:17 PMsiafulinux says:
Nicely done!
Jul 11, 2011. 12:52 PMPolarize says:
Great instructable :D nice video as well, although it would of been nice to see the stethoscope actually working :P
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2347
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
