3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Electronic Wart Removal - No Blood! Little Pain.
I had a problem with wart removal over the years. The results have been anything but spectacular. I have tried most of the 'normal' methods,
Burning - turns out the vapors are not good for you. I still have a scar on my hand from a doctor removed wart during childhood
                Chemical – Compound-W
Freezing with liquid nitrogen – Dr Scholl’s Freeze Away
Even doctors cryosurgery (freezing).
I just couldn’t do the ‘wack-it-off’ method seen on some Instructable.
Still nothing worked to permanently remove the warts.
I have wanted for many years to build a circuit I saw on the internet.  The claim: close to 100% effective, even large warts.  The circuit is very effective with warts on the hands which are the hardest to remove.  There is minimal discomfort during the process, and no scaring.
It is the Wart Zapper by Thomas Scarborough.
As requested by the Webmaster – I will not print the schematic or their PC board here. (They are wrong and will not work anyway! I will only show my corrections here.  You will have to go to their site to find the rest of the circuit.)
You can find it here the Wart Zapper by Thomas Scarborough
Another similar circuit is here  macroware wart zapper
And if you would rather just buy one, check out:  wartabater
The article for the Wart Zapper is great.  Listing the history of electronic wart removal, and how the circuit works.
I was skeptical!  An electronic circuit, on the internet, that is supposed to remove warts – and runs off a 9Volt battery?  The professionals are using cryosurgery (freezing), if this other method really works why aren’t the professional also using it?
The circuit is very simple, but over the years I never made it as I was having a somewhat difficult finding the parts from one source – and cheap as I am, I didn’t want to pay for shipping twice.
So that is how it stayed for several years, my warts just getting bigger and in the back of my mind a circuit that ‘might’ work – still unmade.
I would just try some other ways like Dr Scholl’s Freeze Away just a few more times trying to keep this one somewhat small.  I also went to the doctor’s office, but still nothing would get rid of them.  Sometimes I would hide the big one with a Band-Aid.
Well I finally had it!  The warts kept getting a little bigger and bigger.  I couldn’t take it any longer.  Skeptical or not – I had to see if it worked.
Step 1Parts:
Parts:
I found I could get the parts needed through Jameco Electronics.  Jameco does have some minimum part orders, but they were for the smaller items. So it was still cheaper than going to Radio Shack.  (Other sources are available; I just found Jameco somewhat easy to use their internet site).
I’ll only give the part number on the parts I couldn’t scrounge around for.
Part Number    Qty    Part
1          Copper clad board (2.25" x 1.8").  I still had a big piece of this lying around.
1          9V PP3 "matchbox" battery
11280              1          Battery clip for battery - or suitable case with internal battery terminals
                        1          Panel mounting on-off switch.  I found a great one on an old toy fire truck.
18914              1          Suitable ABS plastic case approx. (4.875" x 2.5" x 1")
                        1          1 meter (1 yard) plastic shielded wire for the electrodes.  I used a shielded audio coax cable.  I used the shield for the conductor.
                        1          15 cm (6") long brass tube for the dispersive electrode.  I used ¾” diameter brass pipe from Lowes (hardware store).
                        1          Needle sharp tip filed off - for the active electrode.  I used a tapestry needle.  The tip is already rounded – no filing necessary!
                        1          Etchant if a PCB needs to be etched. Radio Shack sells some for about $10.  (See instructables for some cheaper methods)
                        1          Solder
Semiconductors
782823            1          6.8V Zener diode (¼-Watt is adequate)
                        1          Green LED (no other color)
151247            4          1N4148 signal diodes
670207            1          IRF610 power "logic" MOSFET (alternatively IRF510, BUZ11, BUZ22)
51140              1          7555 CMOS timer IC
Resistors
690865            2          1k ¼-Watt carbon or metal film
691260            1          47k ¼-Watt carbon or metal film
691104            1          10k ¼-Watt carbon or metal film
255573            1          470k or 500k potentiometer, carbon track Linear taper.  This is really not needed.  I leave it full on all the time now.
                        1          Knob for potentiometer. Scrounged from some old equipment at work.
Capacitors
332427            1          680pF polyester or ceramic
15272              2          100nF (.1 uf) polyester or ceramic
25541              2          220nF (.22 uf) polyester or ceramic
94432              1          100µF electrolytic 16V or higher
The parts only cost around $23 including shipping.  Extra parts added a little more.  With scrounging you could possibly do better.
 My order was in.  I had the parts in 2 days.  I was off to make my PC board.
34 comments
Mar 10, 2012. 10:12 AMmhanyi says:
Hi, im quite new to building electronics,
my first project was a radio kit from conrad.de an AM radio,
my 8 year old daughter got a wart and she is terrified over it.
I built the
http://www.zen22142.zen.co.uk/Circuits/Misc/wart_zap/wart_zapper.htm
I was quite proud to etch the board myself, the guy in the electronic store helped me get all the correct parts.
connected it up, and it puts out 24v, now I dont have a wart and just moistened my skin and I could feel nothing.I have thick skin.
is there something wrong with this circuit board?
Mike
Mar 10, 2012. 11:09 PMmhanyi says:
I will start with a very clean brass piece, actually mine is a flat copper sheet.
my daughter felt nothing, my wife felt nothing, I know there is 24v in it...
I could send you a pic and a list of my components purchased...
thanks for helping, If i really have to build again i guess i could,
mhanyi yahoo com
Mar 10, 2012. 10:16 AMmhanyi says:
I add comment, is ther instructions for idiots on how to fix
I have it built and a picture would be a great help-remember im an idiot
mike, I can open pdf,s
Jan 20, 2012. 9:40 AMkasamiko says:
Thomas circuit uses a CMOS version of 555, will it care if I used a standard version? like NE555?
Also I can't find BUZ11 in my place instead I got some IRFZ44 lying around..
Will it work for me??
Jan 27, 2012. 6:52 AMkasamiko says:
Hi,
I used NE555 and IRFZ44 with 9 volts regulated power supply..
Tried on my wart I felt like a burning inside or around the wart but it's tolerable..
tried it for less than 2 minutes..i think it's working...:D
Jan 29, 2012. 6:51 AMkasamiko says:
A timer will be handy this time I think..:D
Thanks!
Jul 9, 2011. 10:27 AMgtwo says:
Does the WartaBater really work cause im really interested in buying it but I really really need to know if it works cause I dont have money just to throw around?
Jun 7, 2010. 9:59 PMchemistprof says:
"Burning - turns out the vapors are not good for you." Lol! Maybe you shouldn't make it a practice to huff wart smoke! The combustions products from burning most things are bad for you, but I doubt burning a tenth of a gram a keratin will have any effect on your health.
Jan 5, 2010. 5:05 PMPompRocker says:
The first line of the page at http://www.zen22142.zen.co.uk/Circuits/Misc/wart_zap/wart_zapper.htm says it is new and improved. Now that article isn't dated, which I feel all tech articles should be dated, but has it incorporated your corrections?
Nov 29, 2009. 5:54 AMkill-a-watt says:
Bad  link, but I found it elsewhere on the page:
Your link has a final forward slash at the end of the URL. That should not be there
Nov 13, 2009. 9:50 AMsusantrixi says:
I actually bought a wartabater because I was at my wits end with warts that would not go away, or would go away only to come back.  It worked  like a charm on 1 plantar wart, 1 finger wart, and 1 VERY embarrasing wart.  The wartabater makes sense and actually worked on 3 very different warts.  I am very thankful.
Sep 15, 2009. 10:42 AMChoscura says:
I had horrible warts for over 12 years. one wart on my food in particular was treated every way the doctors knew how- cryosurgery, duct tape, cutting, cauterizing (burning), 2 types of lasers, acids, and various chemicals. what finally worked? tobacco. I put some tobacco on a wart on my finger and held it in place with a bandaid- I used a drop of honey to make the tobacco stickier the first time, since it was dry, the second time I didn't- and within a few weeks, all warts, everywhere on my body, had completely disappeared. something like 24 major warts and probably other small ones I didn't know about yet.
Sep 5, 2009. 8:51 PMfrollard says:
You don't mention trying the duct tape technique... Very good instructable, neat project...thankfully I've not had a wart in a decade so it's not much use to me :P
Sep 5, 2009. 9:34 PMWeissensteinburg says:
Doesn't that require leaving it on for a few weeks? That's not always practical, depending on where they are and how much you care about other people's opinions. He mentions hiding the wart with a band-aid, so I doubt the questions that would arrive by having the same piece of duct tape on your hand for a month would be welcomed.
Sep 6, 2009. 4:51 AMfrollard says:
Use duct tape and a small bandage to keep it hidden. Honestly, if covering it with less than a penny's worth of tape is not aesthetically pleasing, by all means, shock the crap out of it :D
Feb 12, 2011. 5:59 AMlegallyme says:
@frollard- It seems designing and putting something like this together requires a lot of work. It also seems like a lot of work to read something that is of no use to yourself. Furthermore, it sounds like an enormous waste of time to care so much how and why other people choose the treatments they choose for their condition(s).
As the post stated that's being replied to, duct tape is, "not always practical." Is there a reason you are so intent on convincing others about why their decisions are wrong?
btw- this article is 1.5 years old, so I don't expect a reply. Just for posterity...
Feb 12, 2011. 12:58 PMfrollard says:
I was not judging on the project's merit - clearly it works. If you understood my message in anything other than that tone you are mistaken.
I a firm believer in dabbling, repairing, and 'doing things more complex than they need to be'. I haven't yet posted my instructable on how to build a crane on your balcony to get couches out of an apartment without your landlord knowing. :) More work? depends on how much you like taking couches down a spiral staircase.
In this case, it seemed like the ible was tantamount to building a car to drive over fruit to make juice instead of 'just crushing the fruit'. Is it a bad thing? no. I simply offered a simpler 'less aesthetically pleasing' solution, which, as it turns out is commercially available in a skin/transparent patch variety now specifically for wart removal. Please do not take my comments as slight, they are simply constructive criticism.
I'm rather hurt that you would flat out 'ask me to leave' in so many words simply because I disagree with you. That is not in the spirit of instructables at all. Good day sir. (or madam)
Feb 13, 2011. 3:29 PMfrollard says:
And there is the answer right there: :)
"why not just use duct tape?"
"because this works well, and is cheaper than the commercial solution"
Solved!
Feb 12, 2011. 10:22 AMlegallyme says:
@jdl- Sorry you didn't spend enough time reading what I wrote to see that the message wasn't directed at you. "@frollard" was the first thing in my post. In whatever case, I was actually defending your work, but maybe that was a mistake.
Jun 29, 2011. 7:06 AMpenguin.waddle14 says:
@legallyme- JDL wasnt talking to you, they were talking to frollard. they knew you were defending them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jdl
