Electronics for Absolute Beginners, Chapter 3
 by elektrobot
Step 23: Biasing Diodes
A diode is a device that allows current to pass on end and blocks it on the other end.
A simple example of a diode is the LED (Light emitting Diode).
A diode can be forward or reverse bias.
In a circuit where DC is the voltage source, a diode can only conduct when it's forward biased. This is because DC only travels one way, from positive to negative.
In a circuit where AC is the voltage source, we can do the following:
We can FORWARD BIAS a diode - if we want it to conduct with a positive voltage.
We can REVERSE BIAS a diode - if we want it to conduct with a negative voltage.
This is because in an AC voltage the polarity alternates from positive to negative and vice versa. So the current can travel two directions the polarities change.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
