3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Electroplating A Quarter
video How to Electroplating A Quarter
Quarters are nice and silvery. What if they looked like a big penny? This video shows you how to electroplate metal objects.
How to Electroplate a Quarter
Attach a piece of copper (a penny should work) to the positive + end of a battery
Attach the quarter to the negative end -
Fill a beaker/glass with a copper salt...copper chloride, copper nitrate (any salt should work, even vinegar)
Fill the beaker with water and place in your metals
27 comments
Jul 11, 2011. 5:47 AMBBFNN says:
umm... will doing this expose me to harmful materials?
Jan 25, 2008. 3:01 PMnf119 says:
Good video. It looks like the copper got oxide (or maybe it was just the camera). Pure copper should be shiny. I used 1.5V in my instructable. It took much longer since I didn't have any copper compounds.
Mar 26, 2010. 5:54 PMNyxius says:
right,  you were seeing copper oxide.  Higher voltages result in over reactions at the electrode (a.k.a. burnt copper).  Best way to get a good result fast?...
Attach multiple low voltage batteries in parallel (to increase the amps),  heat the solution (to increase ion transport), and somehow agitate the solution (to mitigate crystal growth).
You should have a decently thick plate in seconds to minutes (depending on a lot of factors).
Mar 26, 2010. 5:55 PMNyxius says:
also keep the electrodes at least 3 inches away from each other.  Decreasing distance has the same effect as increasing voltage.
Mar 2, 2011. 3:02 PMEl Mano says:
So high amps and low voltage, and seperation between electrodes keeps the electrodes from corroding?
Mar 2, 2011. 4:23 PMNyxius says:
right, you're aiming to have the local voltage potential lower than 1.4 volts. Look up hydrogen potential (single electrode electrolysis), this will give you a better idea on how separation affects your electrodes.
Mar 3, 2011. 3:30 PMEl Mano says:
I'm trying to build a long term electrolysis unit that can be run for long periods at a time. I'd rather not have to think of some complex way of designing changeable electrodes, and I don't want to keep buying batteries for the carbon rods; I want something I can just glue in and let sit. Unfortunately, I'm not sure this is physically/chemically possible. Using very low voltage, say, .5v, and carbon rods from heavy duty carbon-zinc batteries, placed several inches away, would the carbon still corrode?
Mar 3, 2011. 4:11 PMNyxius says:
That system would work, but the carbon is going to decay simply because of the fact that you are using them as anodes. I would suggest using a copper anode resting on some sort of slanted brush contact. this would allow the electrode to slide further into the solution as it wears out (kind of an auto feed mechanism). as to electrode distance... you don't have to worry about adjusting the distance, just be aware that there is a minimum distance and the more you encroach on it the more you're going to have problems with oxidization. Better too far than too close.
Sep 30, 2008. 4:05 PMRadioactive_Legos says:
What would make this work quicker - higher voltage or higher amperage? Also, does it have to be some sort of copper salt or can you use table salt - I got comfused when you said vinegar would work also.
Mar 26, 2010. 5:47 PMNyxius says:
Also higher amps means faster reaction.  This means shorter plate time.  If you leave it in too long without something to randomize the direction of crystal growth large metal crystals will start to form on you surface.
This has more to do with fluid physics than chemistry.
Simplest solution...
High amps - Multiple shorter dips in the electrolyte.
Dec 14, 2010. 9:48 PMFiction says:
What exactly are the crystals that form? I'm trying to troubleshoot my electroforming setup. I've been finding that eventually, all of my baths begin losing their effectiveness; simultaneously, transparent blue crystals form both on the copper anode as well as in the bottom of the container, using small pieces of dissolved copper as seeds.
Agitating seems to help, but inevitably, some crystals form, and get filtered out when I'm cleaning the solution. I'm interested to know a little more about the chemistry that is going on so I can replace the right stuff to keep the solution balanced.
Mar 2, 2011. 4:33 PMNyxius says:
The crystals that form are copper salts of the ion conductor that you are using. salts are forming because you salt concentration is reaching critical density. either add more water or add a sink layer.
Mar 26, 2010. 5:43 PMNyxius says:
You are aiming for higher amperage. Higher voltages can lead to copper oxides forming (the black copper coating in the video).  It does need to be a copper salt.  When he said to use vinegar it was with the intention of making your own home made salt.  Almost all metal acetates are water soluble.  By adding vinegar to the solution the vinegar eats the copper electrode forming you salt until it reaches a proper density where it can coat the object at a reasonable speed.
Nov 22, 2008. 8:07 AMbob the builder #1 says:
just use lemon juice
Jun 21, 2010. 11:29 AMharry88 says:
that cant be real it takes at least an hour to electroplate
Oct 30, 2009. 6:51 PMwoody558 says:
Will regular table salt work?
If not, where can I get copper salt?
Mar 26, 2010. 5:39 PMNyxius says:
No, table salt will not work.
Your copper electrode will corrode to form copper hydroxide and your quarter will just sit there and create little hydrogen bubbles.
The copper that forms the coating comes directly from the salt.
The only reason why you need a copper electrode is to replenish the salt. Otherwise the reaction would slow down as the salt was depleted and eventually you start having unwanted reactions like the hydroxide I just mentioned.
Dec 1, 2009. 8:58 PMandrewortman says:
Technically, but it wont allow as much current to flow as a copper mixture. It'll take a lot longer
Sep 27, 2009. 10:30 AMlokilc62 says:
Will a 12 volt car battery work or is it to much juice
Mar 19, 2009. 10:59 AMReCreate says:
how to electroplating a Quarter? Thats probably the worst grammar i've seen all day...
Aug 1, 2008. 3:27 PMszechuan53 says:
i was electroplating some zinc onto a rusty drill bit. i let it sit for a while, while i ate lunch and went to the hardware store. when i came back, crystalline zinc was growing like crazy all over it? could you tell me what i did wrong? (if it helps, i used a zinc acetate solution.)
Feb 21, 2009. 10:44 PMShadowfury says:
Yeah, you let it sit too long. The zinc plated the bit, then continued to plate until crystalline zinc grew, then the crystals grew larger and larger.
Jan 24, 2009. 2:15 PMphotis22 says:
Im using a model train transformer for mine which has AC and DC outlets, which one should I use, or does it matter?
Feb 3, 2009. 6:05 AMBryan Smith says:
Polarity matters... Use DC current only. the quarter to be plated should always be attached to the negative lead. the object attached to the positive lead will be eaten away with time.
Oct 20, 2008. 7:02 PMGilo says:
the amperage has an effect on the smoothness of the plating. high amps tend to deposit the plating material at a higher rate resulting in a rough finish.
Apr 8, 2008. 10:42 AMmattccc says:
did yu use copper suflade
Jan 30, 2008. 9:27 PMsensoryhouse says:
i'm lovin the custom paper background in the video
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
185
Author:kentchemistry.com
