3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Elegant Ornaments from Scanner Mirrors
I've saved the mirrors out of every scanner I've dismantled, planning to make them into a window hanging or a mobile one day. Then I thought they might look cool reflecting the lights on the Christmas tree...so I did this instead. They have a cool icicle-like effect. I've entered this in the Homemade Holidays contest, be sure to vote for your favorites!
These ornaments are surprisingly simple to make without a lot of special equipment. I used a drill press and belt sander, which I recommend it they're available, but really the only specialized tools you need are a glass cutter and a glass drill bit.
Step 1Stuff Ye Need
Stuff Ye Need
It looks scarily long, but that's because I ramble.
Materials:
Scanner mirrors. These are the long, thin mirrors that reflect the image from the scanning head down to the CCD or CMOS or Polaroid or whatever it uses. They're front-surface, which makes them very shiny on one side, but also relatively shiny on the other side. Shiny is good.
-Hanging things. I just used a bit of fishing line, but you could also use thread, paperclips, twist ties, whatever works for you.
Tools:
-Glass-cutting bit. You can probably get expensive ones if you feel like wasting money, but I used a 1/8" spade-point bit from an $8 Harbor Freight eight-piece set. These spade bits are basically a little spear of pure tungsten carbide, making them very very very hard, but also somewhat brittle and prone to heat problems. We'll address that later.
-Drill. Drill press if at all possible, it will help keep the pressure constant and the angle straight.
-Sanding thing. I like mah belt sander, but a bit of sandpaper and a block of wood works too.
-Glass cutter. Again, there's lots of different ones-mine is something similar to this $2 tool, also from Harbor Freight.
-Combination square. Make your cuts purty.
-Old mousepad. It's a big square of neoprene, which is excellent for supporting the glass while drilling it.
-Liquid Coolant Dispensing Device. I like a spray bottle filled with a 50/50 mix of rubbing alcohol and distilled water...it acts as both a cutting fluid and a glass cleaner.
-Lintless rag. Save the Shiny!
-SAFETY GLASSES. WEAR THEM.
19 comments
Nov 29, 2010. 4:36 AMcraftyv says:
Great ibles. Any suggestions for how to hang the glass without drilling holes as I don't have the tools. They are lovely. My mirrors are several widths and lengths and some are too narrow to drill. Look foreward to any replies.
Apr 7, 2011. 10:39 AMNaturalCrafter says:
You could use a light weight metal to frame around the shiny, (like used for cut glass work( or braid some twine rustic with a tiny red bow a top and fix that with hot glue, or cement.
Apr 7, 2011. 8:51 PMcraftyv says:
Thanks for your reply. I have some wire, I might try that.
Feb 8, 2011. 8:05 PMDr Qui says:
Nice reuse, I scraped a scanner not long ago and saved the mirrors because they looks nice, never thought of this as a use for them.
I see you are a man after my own heart who never misses the opportunity of autopsying dead tech and harvesting all the fun bits.
keep up the good work.
Nov 7, 2010. 11:36 AMchrissysno says:
I love this. It's very pretty. I'll try it this year. Thanks!
Jun 1, 2010. 6:29 PMcraftyv says:
I absolutely love these ornaments but please tell me , in words, where you get the scanners from I have no idea what the letters mean.
They are just what i need to make my kaleidoscopes from.  Great . I can't wait.
Dec 26, 2009. 6:05 PMoldestgeek says:
If I get it done i will try to post a picture.
BTW Has anyone tried a wet tile saw to cut these with? I left the ones i made long because i do not have a glass cutter handy, and i was not able to fire up my tile saw...yet.
Dec 25, 2009. 4:29 AMoldestgeek says:
The Xerox Phaser i took apart had 1 mirror for each color, and a couple more with a square profile. Sadly, i have thrown away many of these printers without "harvesting" the good stuff from them. There just is not enough time in the day!
I plan on gilding one of the square profile mirrors with Gold leaf = extra shiny :-)
Dec 24, 2009. 5:27 PMoldestgeek says:
Hey, the bits i ordered from Feebay just got here so i made a few of these! Just in time for Christmas:-) GREAT reuse  of mirrors! I got a slew of these mirrors from a color  Laser Printer.
Dec 24, 2009. 3:19 PMSunbanks says:
I liek shiny things :D
Dec 24, 2009. 3:17 PMyokozuna says:
Nice project, but needs more dangerous tools than just a glass cutter.  Still, five stars. :)
Dec 24, 2009. 3:18 PMKentsOkay says:
 Very cool, I like the front pic too!
Dec 18, 2009. 1:55 PMcanida says:
Ooh, shiny!
Nice reuse project, and great intro picture. ;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
99
Author:CameronSS
I'm a geeky college student without enough free time or funding to do most of these Instructables...sigh... Topeka is my hometown. I'm at school in Wichita about 80% of the time, but I like Topeka be...
more »
