3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Elephant-Shaped Piggy Bank
Step 4Clamp, glue, and sand.
It is best to align the inner cavities as much as possible, because that is a very difficult surface to sand later on.  I used dabs of wood glue spaced evenly on each surface, and then clamped the four elephants together to dry overnight.
Now comes the longest part: lots, lots, lots of sanding (in terms of my project specifically).  Even using a power sander still takes a while, depending on how well the initial templates line up.  The sharp curves are the hardest part to get at, so if you chose a more rounded shape, that should be much less work.  Because this will be touched by the user, the final grit should be between 220-500, rendering the elephant splinter free.
You can tell the difference sanding made between these two pictures.
1 comment
Jun 14, 2010. 2:04 AMiMakeItHappen says:
i would suggest also using a hand file for this part, one with a rounded edge and one with a flat edge, it will make your sanding job alot easier...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:guyzo35(The Moustache Diaries)
I started a wood shop in my basement during the Summer of 2009, and have been teaching myself techniques and skills through the project's I've built, both for myself and for others. As a mechanical e...
more »
